Truck Problem
Old 06-16-2005, 04:19 PM
Sleepy53's Avatar
If you cleaned th K&N some of the oil could of gotten on your maf screen causing it to run worse, but I dunno (just my .02)
Old 06-17-2005, 08:09 AM
BobbyBa's Avatar
It was doing it before I did that.Good Suggestions Any more
Old 06-17-2005, 08:52 AM
sd155racer's Avatar
Coolant temp. sensor
Old 06-17-2005, 09:33 AM
BlackLM7's Avatar
Does your 2000 truck have stock wheels/tires?
Old 06-17-2005, 09:46 AM
14 Second Truck Club
JERRY2500's Avatar
I forgot about that one. I had it happen to another truck i had. But it was the t-stat. The temp would get just high enough to drop the timing and just kill the power.
Old 06-17-2005, 10:07 AM
10 Second Club
11SECSS's Avatar
My 05 SS only get 13.8 mpg no matter what i do.....you should check for codes even if the light is not on.
Old 06-17-2005, 11:47 AM
BobbyBa's Avatar
It does have the stock wheels with 75 series tires.Can you ohms out the temp sensor to see if it is bad?I will see about get a scanner and checking for codes.
Old 06-27-2005, 09:48 AM
BobbyBa's Avatar
Just wanted to let everyone know what was wrong with the truck.I checked for vacuum leaks and did not find one.I checked the pvc valve and it looked brand new.No oil on it at all.I reinstall and made sure it seated.I have put around 200 miles on it this weekend and I still have a little over half of a tank.I am going to drive it all week and see what happens.It looks like that was the fix.I was only getting about 250 to 275 mile per tankfull before.
Old 06-28-2005, 12:01 PM
4SHONGO's Avatar
Open the exhaust
Old 06-28-2005, 12:04 PM
1FUNZ71's Avatar
Lets us know how it turns out
wrb002
08-31-2015 12:00 PM
Mossyoakglock
07-17-2015 08:30 AM
black6spdz
07-16-2015 01:32 AM
Suburban2500
07-13-2015 09:57 AM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: Truck Problem
