Truck runs like crap when i get to 1/4 tank....
Old 09-24-2009 | 05:14 PM
dirt track racer 81's Avatar
Corey what pump you have?
Old 09-24-2009 | 05:16 PM
Ender06's Avatar
hmmm, mine is RETURN style, but I'm not sure if it matters. Mine was doing EXACTLY the same though. If you look at the Thread above, I'm now getting a new fuel pump.
Old 09-24-2009 | 05:17 PM
BlackGMC's Avatar
Resident Retard
Stocker that came with the truck, 45k on it...
Ya i saw your thread...
I don't mind buying and changing the pump and all that crap, i just hope it is the problem... I guess i need to get a fuel pressure gauge...
Old 09-24-2009 | 05:22 PM
Ender06's Avatar
ME TOO...I had the fuel pressure checked at the local garage, and it was between 50 and 60, but I didn't get to check it when it was low before it went out, so it was reading fine with more fuel in it.
Old 09-24-2009 | 05:37 PM
00ChevyScott's Avatar
Wearin' da big hat
When mine is below 1/4 tank, the fuel pressure drops off dramatically at more than half throttle. But if you put more gas in it, its fine. But its getting worse
Old 09-24-2009 | 06:22 PM
xlcooplx's Avatar
are you guys letting your gas level go below 1/4 tank before filling up? i try to keep mine above 1/4 so the pump doesn't burn up...45k just seems a little early for a fuel pump..atleast IMO
Old 09-24-2009 | 06:26 PM
Wearin' da big hat
It's pretty hard for me since 95% of the time my gauge doesn't work.
BlackGMC's Avatar
Resident Retard
I usually let me go until the light comes on, lol.... why in the hell do i have to refill before 1/4 tank?
Old 09-24-2009 | 06:38 PM
fastrt's Avatar
11 Second Truck Club
I got a fuel pressure tester if you want to borrow it. or parts store has ones for $35 i think.
Old 09-24-2009 | 06:42 PM
xlcooplx's Avatar
Believe it or not, the gas in the tank keeps the pump cool...when you continuously run the tank low, the pump begins to overheat and causes premature failure. Your truck is a 04..iirc, the fuel filter is in the tank. if so, i'd definitely change it when you're replacing the pump. You'd be suprised how much harder the pump has to work due to the filter being clogged.
Quick Reply: Truck runs like crap when i get to 1/4 tank....
