Truck runs like crap when i get to 1/4 tank....
Old 09-24-2009 | 07:26 PM
  #21
dlt76028's Avatar
when mine did that, it was the fuel pump.
Old 09-24-2009 | 07:34 PM
  #22
BlackGMC's Avatar
Resident Retard
Originally Posted by xlcooplx
Believe it or not, the gas in the tank keeps the pump cool...when you continuously run the tank low, the pump begins to overheat and causes premature failure. Your truck is a 04..iirc, the fuel filter is in the tank. if so, i'd definitely change it when you're replacing the pump. You'd be suprised how much harder the pump has to work due to the filter being clogged.
Where do you buy the filter?
crap.
Old 09-24-2009 | 07:36 PM
  #23
dlt76028's Avatar
its hard to remember cuz i also changed the o2's around that time and it fixed everything...
Old 09-24-2009 | 07:39 PM
  #24
00ChevyScott's Avatar
Wearin' da big hat
crap.
Oreillys sells em.
Wix# 33481
Old 09-24-2009 | 07:42 PM
  #25
BlackGMC's Avatar
Resident Retard
Originally Posted by 00ChevyScott
Oreillys sells em.
Wix# 33481
is that for the returnless style????
Old 09-24-2009 | 07:57 PM
  #26
budhayes3's Avatar
PT's Slowest Truck
I remember seeing pics of a factory pump where the hose from the pump to the fitting got a pinhole in it and and created lean issues. I've noticed that my vacuum gauge goes down 1 mm/hg when I get to a 1/4 of a tank also, and the truck isn't as peppy....or wasn't as peppy lol.
Old 09-24-2009 | 08:00 PM
  #27
Wearin' da big hat
It doesn't matter, same filter
Old 09-24-2009 | 08:01 PM
  #28
Wearin' da big hat
Should look like this one
Old 09-24-2009 | 08:17 PM
  #29
BlackGMC's Avatar
Resident Retard
WTF! my damn filter is on the inside of the tank and is apart of the fuel pump... Yours is a return style that has an external filter mine is internal and is not replaceable...
Old 09-24-2009 | 08:19 PM
  #30
BlackGMC's Avatar
Resident Retard
Interesting....
Quick Reply: Truck runs like crap when i get to 1/4 tank....
