Truck vs. car waterpumps
Old 01-03-2008, 07:49 PM
87octane's Avatar
Default Truck vs. car waterpumps
Has anyone tried tearing apart a car water pump body and restuffing with truck pump shaft and pulleys to make a forward facing truck pump? It would open up the options for intake manifolds on 5.3/6.0's. I've been eyeballing that new Weiand street warrior with those long long runners that would make beautiful torque on a truck motor but the TB location is the same as all the car intake manifolds. I think the alternator bracket could be carved up to clear it without too much grief. How bout water pump choices. Anybody?
Old 01-03-2008, 07:54 PM
1TRUESS's Avatar
If you have a non DBW throttle body you can use a nnbs water pump!
Old 01-03-2008, 08:07 PM
adam1803's Avatar
You can also just use a car waterpump and press the truck pulley onto it.
Old 01-03-2008, 08:09 PM
amadeospike's Avatar
I tried that, but they could not take off the pulley on the car WP. Do you know someone who can do it?
Old 01-03-2008, 08:38 PM
dirt track racer 81's Avatar
i used a shop press and pressed the pulleys off..you have to take the back cover off and and press the shaft out of the pump first (press on pulley side)...my old pump i originally had was an f body housing and internals with truck pulley
wrb002
08-31-2015 12:00 PM
Austino
07-30-2015 03:28 PM
therock
07-25-2015 09:23 AM
black6spdz
07-16-2015 01:32 AM
Quick Reply: Truck vs. car waterpumps
