Truck wants to die when coming to a stop! Help!
Old 03-08-2011, 08:16 PM
kciSS05's Avatar
Default Truck wants to die when coming to a stop! Help!
So the past week it has been getting warmer here in mich. During the winter months I have to let my truck warmup for atleast 4 mins before I can drive without my truck dieing. Well sense its getting warmer out I figured it would stop and not die. Well today my truck died about 4 times. It only dies when I'm coming to a stop. I do have a stall cam headers the normal stuff. Could this be a fuel or ignition problem? I have not cleaned my maf in awhile but idk im lost and don't know where to start. It surges down to like 200rpm then comes back up to 700 800 rpm. Please help!?
Old 03-08-2011, 08:39 PM
Bigschwerm's Avatar
Mine did the same after the cam install. It needed more idle air in the tune... that and I drilled the hole a little bigger in the throttle blade because my IAC valve was full open at idle.
Old 03-08-2011, 08:47 PM
nikon2011's Avatar
definitely sounds like the tune needs to be tweaked. IMO
log some air trims!
Old 03-08-2011, 08:52 PM
lady3bglover's Avatar
log some air trims!
I agree
Old 03-08-2011, 08:54 PM
kciSS05's Avatar
Thanks guys for the help. I have had my cam and stall in my truck for about a year and a half now and this just started happening. Hope this helps with some more info! Thanks guys! And I will have my tuner look into my tuning and see what's going on
Old 03-08-2011, 10:44 PM
cdub81's Avatar
Clean the throttle body and tweak the tune some. Mine did the same thing it was even worst with the AC on
Old 03-09-2011, 08:06 AM
allballz57's Avatar
check your cylinder compression,what heads are you running?
Old 03-09-2011, 12:22 PM
kciSS05's Avatar
Thanks I will clean the tb aswell! And my heads are stock 317 with patriot duals and harden rods
Old 03-09-2011, 12:37 PM
allballz57's Avatar
o.k,making sure you didn't have ported ls6 heads! I just had an issue on my cousins truck where his ported ls6 heads were cracked and leaking in the intake runner of the #7 and #2 pistons!It ended up costing him his motor,and the symptoms where the same as yours at first! Down cylinder compression will also cause this,but your problem might not be this serious.
Old 03-09-2011, 12:47 PM
Wearin' da big hat
00ChevyScott's Avatar
How big of a cam did you put in there?
Quick Reply: Truck wants to die when coming to a stop! Help!
