trucks with no cats, I need some help
Well I think, may have done it now
Was at the exhaust shop. May have gotten too greedy, have no cats now. So wanted to do some ve tuning notice some cells +7 range. but cutouts are nice easy to get to.
But as soon as I get over 2300rpm, REDUCE ENGINE POWER, and get a code :
"airflow to tps signal corraltion high"
What is this only happens when I go mafless ???
help???
help???
help???
help???
You definately need to add some fuel in those cells. All of mine are at zero or negative.
I think the NA guys say to try to get them to +3 to -3 or something along those lines.
No dice, disabled 101 thru 103 and set maf fail to 0
still gettin DTC p1514 "airflow to tps signal correlation high"
Last time, had to reflash the pcm so it would run.
FlowmasterMufflers
07-17-2015 03:26 PM
FlowmasterMufflers
07-09-2015 12:00 PM
FlowmasterMufflers
07-09-2015 11:35 AM
