true duals 2 bullets = too loud
Old 03-18-2010, 06:58 PM
SSmikeSS's Avatar
Default true duals 2 bullets = too loud
Well I just finished my install. I have the 2 Dynomax bullets longtubes, gutted cats and dumped about 10" behind the bullets. DAMMM is it loud! It would be awesome at the track. Also it drones in the cab pretty bad. Is there any to tone it down a bit, with out getting new mufflers?? My guess is it will only get louder over time.
What do you think?
Thanks,
Mike
Old 03-18-2010, 07:21 PM
outlawz2004's Avatar
put on longer tailpipes, or use some resonated exhaust tips. I used some borla resonated tips one time and it completely shut the lontube no cat exhaust up. Barely louder than stock.
Old 03-18-2010, 08:02 PM
DAYTONA81's Avatar
i got the same set up like you but duals with a x pipe and i had them dumped and they were to loud so i had it extended to the back and now it sound better, not as loud unless you following me ..lol
http://www.youtube.com/watch?v=HFlI3JXgjxI
Old 03-19-2010, 06:08 AM
SSmikeSS's Avatar
Thanks guys
How much further should I extend the tail pipes?? I still want them dumped.
Old 03-19-2010, 06:57 AM
BlownChevySS's Avatar
x-pipe will def help the drone. I don't have the cats, true duals with TOG headers, and 2 Dynomax mufflers. The sound used to annoy me til I put in the x-pipe. And I would extend the pipes to go over the rear axle and dump
Old 03-19-2010, 08:02 AM
rjaime's Avatar
ya'll have cat sims? i wanna cut out mine but what about the codes?
Old 03-19-2010, 09:47 AM
Tweek's Avatar
i have midlength headers with three inch bullets dumped about two inches pass the cab and its not that bad. it drones alittle on the interestate but i just turn the radio up. its a small price to pay for it to sound so mean.
Old 03-19-2010, 05:47 PM
SSmikeSS's Avatar
What does a x pipe actually do??
I left my cats on for the visual inspection. The codes are taken care of in the tune.
Old 03-19-2010, 06:04 PM
Evil Eric's Avatar
Anything dumped under the truck is going to cause high amounts of drone. if you run the pipes out the side or out the back it will decrease the noise slightly.
Old 03-19-2010, 08:37 PM
PT's Slowest Truck
budhayes3's Avatar
An x-pipe is like a more efficient h-pipe, but besides just balancing out the exhaust pulses, as the left pulse leaves the x it helps pull the right pulse through, and so on. One of the side effects of the x-pipe is a mellower exhaust note.
Quick Reply: true duals 2 bullets = too loud
