TRuTorq cam in a heavy beast
Anyways, that cam you suggested will kill your low end. Something in the 210s/220s is much more suitable.
thanks for the advice all...
I'm gonna go find a weigh scale, now I have no idea how heavy this thing is...
I had thought it would be a little over 6k lbs until reading (don't remember where) about the 8800.
I'll check out the old man cams too, but honestly, I'm finding it a little difficult to know what to think when half of them don't have readily accessible dynos that i can see, and some of the ones I can see start at 3k rpm. I have tried emailing some asking for a recommendation based on my needs, but haven't gotten any responses yet.
I think I've chosen my cam, the vhp butt-kicker. VHP says its the same as the ultra torque but a little rougher idle. Most recommended based on my wants/needs.
Specs are:
DUR @ .004" 272*/280*
DUR @ .050" 210*/218*
LIFT .551 / .551
LSA 114*
I'll also get the spring kit, but should I get rods or rockers as well?
Specs are:
LIFT .551 / .551
LSA 114*
Another very similarly sized cam is Comps 212/218. There's a high lift and low lift version with 1 degree of LSA difference between them. I personally ran the high lift in my 5.3 and noticed great power improvement throughout the band and it is very drive-able.
Don't bother with rockers. You will probably need 7.4" hardened pushrods for that cam, but its always best to measure.
I have an '00 Suburban 2500 6.0 4x4 4l80e 3.73 gears, it weighs 6640 per the cat scales with about 1/2 tank of gas and some tools and crap in the back.
I'm also researching cams, rockers, headers, superchargers. So far it has a magnaflow muffler with stock piping, airaid intake, and Blackbear Autocal tune.
Mine is used almost solely for towing-mostly around 7k pounds right now, but also looking at toy haulers.
Subscribing for the cam info!
Well, I'm pretty sure that I will go with the "butt kicker" cam I mentioned above. They also have a valve kit with duals, retainers, locators and seals. I just need to decide on the rods.
Vinci said this would still be a good cam if i decide to go FI later, if only i can find the $$
Dragr1 - Whoa, our weights are pretty close. I just weighed it at 3030 kg (6680 lbs) with about the same gas and some toold in the back.
Does anyone know if I need to worry about the crankshaft bolt? I thought I had seen someone mention that it should be replaced. and what about gaskets?
I've never done a cam swap where I regretted reusing gaskets. Never had any leaks. I do put RTV in the corners. If you are really scary about it, just change out the water pump gaskets as those can go out from time to time.
