Tsp 220 .581 lift 112 lsa....can it be turbo/supercharged?
Registered User
Like the title states i am just curious on can it be done and work well? everything i have read says no and that you need a 114 lsa or higher. Is this true? Thanks for the input guys. My mods are in my sig.
Of course it would work with a SC but it wouldn't be the most efficient cam out there. I would just run with it for awhile if you go SC and if you are not 100% happy then get a different cam. A split pattern cam with generally a higher lsa would net you the most gain though.
The Tsp220 is a good cam, you can even run nitrous if you wanted to on that cam and see good results..
I know of a member on here running a 224/224 112lsa cam on a radix 5.3, and he is running very nice times, like most say that low lsa is probably not the best but it still works good. Run it and find out if you like it or not, you can always change it later..
