tsp224r or tsp224 xe?
The SDPC springs AKA PAC 1218s (http://www.sdpc2000.com/product/SDL1...S1Setof16.aspx)
were the original 918s, then comp switched manufacturers and they had all the problems. These are cheaper than 918's and a better spring. I see no reason not to get these since they're only $122.
There hasnt been any problems with the 918's in over a year or more, they are a great spring. The PAC springs are also very nice, a drastic improvement over the LS6's, I would steer clear of the LS6 springs. Could run them without a problem, on the other hand....you could have a problem, is it worth the chance? Thats up to you.
The TR220 has a very aggressive lobe, just shy of the XER lobe's from what i've been told (by comp) who grinds their cams.
Any stock spring is only rated/built to handle the cam that it came with. Why would the manufacturer put a bigger, more costly spring on something that doesnt need it? They found the cheapest way to get the spring to handle the size cam they wanted to run, period.
I have 1.85 rockers on my stock springs and cam just for a little kick in the butt, but thats about the only thing that should be done on stock springs of any caliber.
Also, which year of LS6 springs do you have? 01 was .525 lift, 02-04 was .551
Springs are CHEAP insurance against bigger engine damage. You can't shortcut your valvetrain.
Baltimore Whore
02-04. not trying to be an ***, but the valvesprings were not what this thread was started for. i was asking the difference between the lift on the two cams mentioned, not what valvesprings i should use. there has been many people run the LS6 springs with success, plus, i already have them. besides, if a spring DID fail, that would just be an excuse for me to tell the wife i NEED a new motor, and that it is cheaper for aftermarket forged parts than it is for stock replacement parts
Well that doesnt seem like a good reason to get a new motor LOL.. We understand that it wasn't started to ask what springs to use, but it was just stated that it would be a WISE choice to up springs, to 918's or something equal to them. All in all it is up to you, if you made your mind up on the 6 springs go for it..... People just trying to help ya out, that has seen the **** break before, possibly save ya a headache, down the road..
lukn4trbl355
07-19-2011 09:49 AM
