Tune went bad, help!!!
Old 07-30-2013, 01:46 PM
  #91
JoeyGC5's Avatar
Anymore updates?
Old 07-30-2013, 02:13 PM
  #92
Area47's Avatar
not till sunday. stop gettin antsy.
Old 07-30-2013, 02:50 PM
  #93
marineusmc4's Avatar
Originally Posted by JoeyGC5
Anymore updates?
should be putting down 675rwhp after sundays tune.......... jk, but i did save a bunch of money are my car insurance by switching to geico ok i lied again, i have state farm
Old 07-30-2013, 04:03 PM
  #94
JoeyGC5's Avatar
Can't help it, living on the road traveling for work is a lonely life
Old 07-30-2013, 04:38 PM
  #95
dmelvin's Avatar
I wish I would have seen this thread earlier. You and I are running the same cam and I can tell you that this thing will make some power, I'm on 275/55/R20's with heavy akuza wheels and Z71 setup and I put down 310/301 on a Mustang dyno before running into fueling problems. The cam can definitively make some power.
Old 07-31-2013, 08:24 AM
  #96
ya thats what everyone on here and outside of here are telling me. the first dyno run it was at 219. i just had a bullshitter for a tuner was all. im not worried, Area47 is tuning it on sunday so i know my numbers will be higher. i just thought it was funny that i made the tuner retune it and according to him he didnt changed any settings but it went from 238 to 272 lol some people, i tell u. it hauls ***** at 272, i couldnt imagine what the seat-o-meter will feel like if i got 310
Old 07-31-2013, 08:28 AM
  #97
dmelvin, just out of curiosity, what is your pushrod length since you have the same truck and same cam? stock heads right? i have the 862 stock heads
Old 07-31-2013, 08:44 AM
  #98
dmelvin's Avatar
With stock heads you'll need the 7.4 pushrods. I'm running 243 castings milled .030 so I went with 7.350. Comp uses the stock base circle for all their cams I believe.
Old 07-31-2013, 08:57 AM
  #99
yes thats what i put in and was told m=by both comp cams and summit racing. in the beginning of this thread there was some concerns about whether i had the right pushrod length thats why i was asking. ur the first person to comment that actually has this same cam. so if ur making 310 with milled heads, what do u think i might make with my stock 862 heads and current mods? how much hp did the 243 milled ones give u over a stock head?
Old 08-02-2013, 12:09 AM
  #100
dmelvin's Avatar
Couldn't tell you, I didn't get it dyno'd before I did the mods, and I did them all at once. I don't think it will hurt you much since the cam has a pretty low lift. I'm planning on going bigger with the cam at some point in the near future, and I got the heads for less than $400 already milled. My 310/301 was at 5400 RPMs, when fuel pressure went from 54psi to 32. The cam gives a really nice HP/Torque curve.
I also went with .030 (I think) thickness head gaskets to bump my compression to around 9.9:1 instead of 9.5:1
Quick Reply: Tune went bad, help!!!
