Tune went bad, help!!!
Old 08-02-2013, 07:05 AM
  #101
marineusmc4's Avatar
I started looking on craigslist for some 243 heads and found a set. guy is asking 450 for em. im gonna see if i can jew him down to 300-350. once i get a set ill prolly have them ported and polished.
Old 08-02-2013, 12:40 PM
  #102
dmelvin's Avatar
You'll want to mill them .027 -.030 to maintain your compression ratio; they have bigger combustion chambers than the stock 5.3 heads.
Old 08-02-2013, 06:47 PM
  #103
im assuming if porting is removing material than milling is adding material? if i didnt mill them would it adversely affect anything?
Old 08-02-2013, 10:27 PM
  #104
I have a gauge for that
Atomic's Avatar
No, a mill is a machine like a lathe. The acting of using it is called milling....also may be from the fact that material is removed in "mils" or 0.0001 increments.
In a mill, the part stays still and the cutter bit rotates. In a lathe, the cutter bit stays still and the part rotates.
Old 08-02-2013, 11:30 PM
  #105
gotcha. so milling a head decreases compression ratio and porting a head increases, am i understanding this right?
Old 08-03-2013, 12:03 AM
  #106
HuskerZ71's Avatar
Milling I beleive would increase compression. Porting refers to removing material from the ports, around the guides, etc.
Old 08-04-2013, 10:25 AM
  #107
Area47's Avatar
going to try and break 300 in this thing to day.
Old 08-04-2013, 10:27 AM
  #108
dmelvin's Avatar
Milling increases compression. Essentially, you're taking a knife and shaving the entire mating surface of the head, with each pass, you're taking a little material. As you do this, it makes the combustion chambers smaller, therefor increasing compression.
Old 08-04-2013, 12:22 PM
  #109
Gotcha. Is ur truck 2 or 4wd?
Old 08-04-2013, 12:59 PM
  #110
05chevy04yfz's Avatar
good thing i seen this im getting ready to put a maggie 112 on my 06 ss and want to have it tuned in person. not going to use justune for sure. Area 47??? want to tackle it in the furture?
Quick Reply: Tune went bad, help!!!
