Tuning...with LS6 cam?
Re: Tuning...with LS6 cam?
It will run smooth but you will need to increase your shift points to get the full benefit. Shift around 6200 rpms as long as you install the proper valve springs. It will sing above the 3000 range, low end you will lose some.
What rpm does this cam peak at? It's not going to be to high in the 4.8 is it? I'm really just worried about losing all my low end.
I think you do lose a bit down low. But the new power it makes up high is nice!!
Heres a link to SmokUr5.0's thread on the cam. Cam Thread
Here is his dyno graph. DynoJet Graph
im interested in this as well, how much would all of this generally cost, ls6 cam, valve springs, tuning and labor? oh yeah and is this cam alright for a supercharger?
thanks
thanks
thanks
thanks
BUT before that, I'd ditch your HPP3, get a better tune. Get a set of long tubes and a high flow intake. A stall converter and shift kit too. Then I'd look at the cam swap.
Get everything inorder to make better usage of the cam.
at 6200 rpm the ls6 cam isnt even close to maxed out in a 4.8 .....id look around at a lunati or something different, the zo6 cam was made to work in a 5.7 not a 4.8 belive me i just finished my 5.3 last week you will lose a ton of power off the line unless you go with a big stall....look at the lun 550003 thats the cam i have it sounds good... i have a 2800 stall and i still lost a bit out of the hole......also if the max hp in a 5.7 is 6600 for the ls6 in a 4.6 its near 7800 or higher....just my 2 cents .....
