turbo question
Originally Posted by jow02327
Would twin T3/T4 garett turbos be a good setup..... as far as quality and power??? (Or even just one?)
You will need two.... What other mods do you have?
[IMG]
did you fab your own kit?
yeah, you will max out one of those turbos in a heartbeat. 2 is nice...trust me.
What other mods have you done FTD?
they are 1.15 exhaust. i thought they would be to laggy, but they are no that bad at all. hks 50mm gates and hks blow off valve. little cam(hehehe) and ls1 heads which i flow benched and ported at school. I used these heads to lower the compression ratio a bit other things here and there but you get the point.. also running a 75 shot off the line.
i can stall the truck (stock stall......) at 1600 and get 2psi out of it, but it doesnt take long to get to 12psi, maybe 3200 i think. right in that area. if i could do it agian, i wouldnt run a 1.15 on the street. id go smaller. they are nice at the track(street tested, track is closed) because i use nitrous to make up for the lack of boost.
