Which turbo Setup???
I cant decide if i want to run my turbos under the truck beside the tranny or run there up front where everybody can see I orginally was going to run them under the truck and have a sleeper setup but the more I think of having those two beutys under the hood the more it changes my mind. My motor was supost to be done today but its lookin more like next week then I can start on the turbos. So what do you guys think hidden turbos or under the hood where everybody can see???Here's a piture I made up of the under hood setup.Twinturbos
lator
Justin
lator
Justin
do that set up and have one big intake tube coming up the middle of the truck into the tb. i would like to look at the power i got and if you ever had to take them off it would be a ton easier.
Under the hood, and that setup would be sick right there. What size turbos did you end up going with? And I must have missed a post somewhere along the way....what's up with your motor?
theres not a ton of room where the cats sit, plus you will probably have to do a drysump for the oiling since they are below the oil pan. did you start mounting them under the truck, if so post up some picts, i had thoght about it but have never seen it done. I would say under the engine compartment similar to: http://www.bankspower.com/twin-turbo-products.cfm
I say fab two holes in the hood and have both turbos stick out halfway. To make it look good, ceramic coat the turbine housing and down pipe, and polish the compressor housing and inlet tube.
1 Post
put them up front where you can see them and you will have the full effect of the sound. but your under hood temperatures would have to be kept on tap while driving hard and slow lol like you would want to do that. what are you doing with the whipple. pm me with the info on it.
