turbo silverado
Old 01-07-2005, 02:56 PM
stretch104's Avatar
Default turbo silverado
i thinking about getting a silverado and making it into a little parish wannabee. which engine should i go with 4.8,5.3,6.0 what are the hp limits with the stock engines if turbod with the right tuning and fuel supply.
Old 01-07-2005, 03:22 PM
MOOBIES Moderator
Scream's Avatar
If I had it to do all over again, I would get a 2500HD reg cab long bed w/ a 6.0L/4L80-e and 2wd. Cut the frame down to accept a short bed, slap a turbo on the motor and a shift kit and converter in the tranny, put an Eaton out back, and drive the hell outta it.
Might be a little outta your budget though.
Try looking for a RCSB 4.8 w/ high miles. Get a forged 408 first and add a turbo kit later. I think you'll be much happier in the long run.
Old 01-07-2005, 03:40 PM
I wouldnt do the HD id so the regular 2500 as that still gets u the 6.0 and the 4l80 just not as big of frame so it should shed some weight.
Old 01-07-2005, 05:31 PM
what a rush!
moregrip's Avatar
the 2500/1500HD chasis doesn't come in RC or EC, just the CC.
I like the 2500HD advice.......hmmm...........wonder why?
Old 01-07-2005, 05:35 PM
F8L Z71's Avatar
If buying a used/new truck I'd do a 2500HD also. That is if you don't like to modify too much.
Otherwise just do like he did with the 1500 4x4 and put all the HD stuff on it.
I gotta have the ext. cab personally.
Old 01-07-2005, 05:36 PM
if i was going turbo and didn't have a bunch of money i would probably go with a 6.0 block and bore it to 4.100 or 4.030 and use a stock crank forged blower pistons and good rods, nice sized turbo and u could safely run 10-12 psi boost(can run more) on a daily basis and not worry about busting. Oh, and of course a built tranny or 4l80 for the time being.
Old 01-07-2005, 05:45 PM
chris99gmc's Avatar
get a Regular cab v8(5.3 or 4.8.. doesnt matter) with a ton of miles and still Looks good and all other options work.
Drop a slightly used 6.0 in there and a 480le in there(the HD tranny is a MUST... more than the engine size is for an FI setup in these trucks). I would stick to 2wd to save $$$ and weight, but the 4x4 is going to launch better with less money and modification.... a 2wd can launch just as well as a 4by if the suspension is set up correctly.
Get the STS or C motorsports kit(size: gt-67 to t-76). Go with an OBX FMIC for cooling. Use at least a 3000 stall convertor in the tranny and get an Eaton posi for the rear end. Since you have the HD tranny... look into like a 75-100 dry shot of N2O for the 60' times. I would also get a Cam, new heads and springs.
The biggest issue is going to be tuning... MAKE SURE THAT IT'S A DYNO/STREET DRIVEN TUNE!!!!..
Old 01-07-2005, 07:14 PM
14 Second Truck Club
JERRY2500's Avatar
You can get a 2005 Silverado 2500HD
Regular Cab Long Box
2WD LS
MSRP: $28,005.00
Auto-dimming inside rearview mirror with compass and outside temperature display
Custom Cloth seats
Leather-wrapped steering wheel
Outside rearview power-adjustable, heated, black, foldaway mirrors
Power windows with driver and right-front passenger Express-Down and rear passenger lockout protection
Rear-window defogger
Remote Keyless Entry
STS Turbo Extra
Old 01-08-2005, 04:59 AM
sfj
6.0 definately i would say RCSB 1500 as far as the 4x4 it well definately help the launch good luck
Old 01-08-2005, 10:55 AM
Andy's Avatar
Yes, chevy used to make them in rc or ec moels.... they were ld 2500s ... iguess they stopped
Quick Reply: turbo silverado
