typhoon intake swap
typhoon intake swap
I bought a typhoon intake recently. I am looking for a few answers. There is a sensor on the back of the factory intake. On top. Where does this go? And also a hose that goes into the back of the factory intake. How does that pop out? My truck is a 2003 5.3. Thanks for all help!
Thats the map sensor. on the back of intake there is a hole that it goes into and theres a metal tab that holds it in. also make sure you get your brake booster line off the port on the front cause if you use the back one, as you put the manifold on you will break the oil pressure sending unit.
GrooveCityZ71
08-31-2015 12:05 PM
