underdrive pulley?
Old 08-13-2007, 11:34 AM
Ferocity02's Avatar
Yes, you will notice that the engine rev's MUCH faster in neutral, especially with the pulley and the clutch fan gone.
Old 08-13-2007, 11:53 AM
TXARKITEKT's Avatar
Yeah, ASP is what I have and love them. I did both pulleys (crank and alt.) and noticed a good performance gain. After I installed them I went out and did a WOT run...I was at 25 mph and stomped it--it kicked down to 1st and I smoked them all the way through and got a 15' scratch at the 2nd gear shift. Before the pulleys, it only chirped on a 2-1 kick down. I got them from rpmoutlet and got a decent price and a good ship time. I say do both for better performance...
Old 08-13-2007, 11:58 AM
abbo7's Avatar
I did the ASP crank pulley and the LS1 fans and I noticed a big difference in acceleration from idle, especially in the summer. The engine feels much more responsive also. Beside that, I also gained about 2 MPG with the E-fans and pulley.
Old 08-13-2007, 02:02 PM
multmigs's Avatar
Anyway with the 6HI conversion at idle
What is this refering to?
Old 08-13-2007, 02:03 PM
multmigs's Avatar
Anyone know the ASP part number to just the alt overdrive pulley?
Old 08-13-2007, 02:32 PM
TXARKITEKT's Avatar
6HI refers to using all 6 lights at the same time---2 fogs+2 low beams+2 high beams=6HI. That draws a lot of amperage off the alternator to run all 6 lights at once...But BlownHD does have the 160 amp alt though...running a 6HI on the standard 105 amp alt on the 1/2 ton might not cut it...
ASP alt pulley part no: 49-540084
Old 08-14-2007, 10:39 PM
Thechevyman122's Avatar
Are the pulleys a pretty straight forward and easy installation....I just did electric fans, and am definately checking these asp pulleys out...both overdrive and the alternator. more info would be great thanks.
Old 08-15-2007, 12:53 AM
Resident Retard
BlackGMC's Avatar
I would also like to know if it affected anyones AC? Does your AC still cool like it did before the pulley??
Old 08-15-2007, 12:59 AM
ONLYA4.8L's Avatar
Werd.. I did oth fans and pulley..Great mods!!!
Vortec350ss
01-12-2016 10:36 PM
Lthompson
10-02-2015 12:45 AM
old motorhead
09-29-2015 08:22 PM
murderedSS
09-27-2015 10:16 PM
Justin87gn
09-10-2015 12:06 PM
Quick Reply: underdrive pulley?
