UPD intake dyno results
Old 04-24-2003, 09:32 AM
Default Re: UPD intake dyno results
If you take out your lower airbox you will see the bigger hole is a separate peice that you can take a flat tip to and push out easy. The main thing I think helped was that the holes only allow so much CFM to get in and it's not enough...pushing out this peice out leaves no restriction to getting the needed air. There's no way for you to have a water problem by pushing it out.
Dyno runs here at Raging Motorsports usually run $55 for a baseline(3 pulls)
GXPJAY
02-13-2022 08:15 AM
lsxperformance
04-20-2016 12:17 AM
AHelm3
04-08-2016 07:51 AM
dselby25
08-24-2015 07:26 PM
bigsapper
07-28-2015 12:56 AM
Quick Reply: UPD intake dyno results
