UPD intake dyno results
Re: UPD intake dyno results
If you take out your lower airbox you will see the bigger hole is a separate peice that you can take a flat tip to and push out easy. The main thing I think helped was that the holes only allow so much CFM to get in and it's not enough...pushing out this peice out leaves no restriction to getting the needed air. There's no way for you to have a water problem by pushing it out.
Dyno runs here at Raging Motorsports usually run $55 for a baseline(3 pulls)
GXPJAY
02-13-2022 08:15 AM
AHelm3
04-08-2016 07:51 AM
