An update on my truck/ motor build for y'all...
My truck has been down for 2 years this August
But I've finally found enough time and money to get my motor built. It's a 370ci nitrous engine.
I used Mahle forged flat tops and Scat H-beam rods with ARP 2000 rod bolts. Added a ported LS6 oil pump. ARP head studs as well as ARP main studs. Cam is a custom grind for ALL my parts from PatrickG and Thunder Racing. Heads are Patriot Stage IIIs with cometic head gaskets. I origionally was going to run an LS6 intake but came accross a nice low mile ported FAST 90 and I bought an LS7 TB to go on it. Fuel rails are Nasty Performance and I still need to buy the FPR and am still debating a dual in-tank pump or just a single 255. I bought a set of Racetronix 42lb injectors. And once I get it together and running I'll be on the lookout for an EWP. Unfortunately I still only have 1 3/4" headers but the cam is designed to make up for that. Would really like to see a set of Kooks 1 7/8" 4WD/AWD truck headers
I have all other supporting mods that I had on my 6.0. Only difference is that this time I'm running a 2 stage NX kit with 2 10lb bottles instead of the single NX kit I had before. The motor will see a 200 shot and should be capable of handling a 300+(although I don't plan on jetting it that high). Both stages will be utilizing a stand alone/dedicated fuel system with 110 octane fuel.
Still have an FLT lvl5 65E w/ billet output shaft and am now running a TT3000.
I haven't shared what the truck runs or ran before but I'll post up what this new combo will put down. Even though the truck is heavy as hell (5600lbs) I think with the above combo on a total of 200-225 shot mid 11s should be very do-able.
Sounds like a nice build. The injectors and single 255 were enough for my motor and 200 shot, so you should be fine aswell. I have a patrick G. cam waiting to go in mine also and was just curious to see what he recommeded for your set up. Good luck with the project.
My specs were; 226/238 .609”/.607” 114LSA +4 advance on Comp XFI/XFI lobes.
For you, I'd maybe do some more searching to see bout the 42s feeding your motor and a dry shot... but I'd think a 110 shot would be ok just nothing more.
