update to oil pressure issue.
Old 01-07-2010 | 05:56 PM
03 BLACKOUTSSS's Avatar
Default update to oil pressure issue.
I have been driving the truck with the oil pressure gauge pegged. Normal temps, normal everything else, until tonight. I have a new oil pressure sending unit that I planned on installing tomorrow night. Heres the new twist.
Now, at idle, the pressure gauge is pegged. Above 1K rpms, oil pressure drops to ZERO . When I get off the throttle, and the rpms drop below 1K, the pressure goes up to 80 psi again.
can someone tell me what the hell is going on? I am going to change the sending unit tonight, if I have no change, I am not going to work in the morning, and will change the oil, no change, new pump over the weekend. Other than that, I have no ideas.
Anyone?
Old 01-07-2010 | 07:49 PM
terravast4's Avatar
bad guage would be my guess
Old 01-07-2010 | 09:00 PM
All right, I have been outside for a while, haven't changed the sending unit yet, I don't see a way to do it without pulling the intake. I can't even get my hand on the piece, much less get a wrench on it. I had the truck idling for about 10 minutes, no noises, nothing. The truck has oil pressure, I am sure of it. I will swap the switch on Sat. morning.
Before I do that, is there any way to test the switch (or the gauge cluster), to verify the broken part before the swap? I wish I knew someone with a silverado, I just switch bezels, none of my friends have any class.
Old 01-07-2010 | 11:31 PM
Coban's Avatar
Know anyone with HPTuners scanner? Or if EFILive has a like function. Should be able to log oil pressure. The gauges are known to go bad.
If you let it idle for 10 mins, you either have oil pressure or a destroyed engine...
Old 01-08-2010 | 03:10 PM
got it all fixed up. Replaced the sending unit, works just like it did before. Glad it wasn't the gauge cluster.
Old 02-10-2010 | 10:27 AM
1SICKhawk's Avatar
truck is doing the same thing its a bad guage not worth the money to fix just monitor the oil this problem is very common
Old 02-10-2010 | 10:30 AM
EVILGMC's Avatar
remember there is a special bulletin for 03 trucks up to 80k mi for cluster replacement. check with your dealer.
Old 02-10-2010 | 12:31 PM
budhayes3's Avatar
PT's Slowest Truck
Cool deal, glad you got it figured out! Were you able to replace the sending unit without removing the intake?
Old 02-10-2010 | 01:34 PM
Tootall's Avatar
if it's not the sending unit, it's the stepper motor on the cluster . . . $3 dollar part
Old 02-10-2010 | 01:57 PM
MikeGyver's Avatar
Originally Posted by Coban
Know anyone with HPTuners scanner? Or if EFILive has a like function. Should be able to log oil pressure...
Not HP Tuners. It won't log oil pressure because oil pressure isn't read by the PCM. The signal goes straight to the cluster, I think. It might be the BCM. But not the PCM.
blownss27
08-14-2020 09:27 AM
pupi305
09-14-2015 12:40 PM
truefire04
09-11-2015 11:51 AM
superchomper2003
08-26-2015 10:39 AM
05GMC4.8
08-07-2015 10:55 PM
