v6 to v8 swap troubleshoot
What's up everybody,
Trying to see if I could get a little help with my current situation. My trucks a 2009 Chevy Silverado 1500, swapped in a 2008 gen IV 5.3 from a Yukon. The motor was built from scratch, bored out to a 5.7, new larger rods/rings, has a stage 3 TSP cam kit, DOD delete kit, plenty of brand new parts, stock injectors, stock 4L60E trans, brand new starter, sensors, hoses, etc. The original shop doing the swap did a BS job, had the truck for 5 months, didn't finish the job and just couldn't get it running. In the end, I got left with his mess and I've been trying to figure out how to get the truck running ever since. The truck cranks and starts but shuts off after a few seconds and I don't know why, do have a video of the startups and shutting off but unfortunately can't include into the post.
Figured it must be VATS preventing it from running as it also has the security light on and is throwing code P0513. Tried security relearn, didnt work. Had my ECM checked, VATS was already disabled on there. Was told it might be because the shop left my v6 fuse box and fuel pump in even though he told me himself that he replaced them for ones off a v8. Possibly fuel system issue? So I'm coming to you all in hopes of getting any insights on what I might be missing, what else I should look in to, or anything of that sort because I've spoken to multiple different shops and am hearing a bunch of different things. Still hoping to find a shop that can take it in and finish the job but I'm just trying to get a general idea of what the issue might be at hand. (In the photos, the wire harness is a mess because I removed it and had somebody open the wire harness to check all the connections, found a few cut wires but got them fixed. So when I got the harness back we threw it on real quick just to test it out)
So my v6 fuel pump should be okay right? Yeah thats the problem, VATS is already disabled on the computer so it doesnt make sense to me. I was told my wire harness needs a fuel pump control module, and my truck doesn't have one so fuel pump has to get rewired and powered some other way, I think that's where my issue is. I've spent hours researching and researching and a lot of swaps run into the same issue and same codes as I am. Most cases of the whole crank but shuts off/wont start issue lead to the fuel system so hopefully I'm headed in the right direction. Post was just to get outside opinions on everything.
right, thats actually something i heard before too where VATS isn't always "completely" disabled. Ill definitely get that checked out and ill see as well if i could get the tune posted.
Nickie Montealegre Prado
07-16-2019 05:05 AM
