V8 SWAP couple of questions
Old 08-18-2024, 08:20 PM
Registered User
that_1_arkansan's Avatar
Default V8 SWAP couple of questions
Hey all, I’m new here, really gonna try to not make a thread that’s already been talked about but I’ve done some searching and don’t see anything too related. Yes, I’ve read the swap guide thread here. Found One person in a similar scenario, but the solution was to swap the long blocks only but I only have one v8 to go by.
so, I have a drive by wire 4.8 LS. It’s been a little project me and my dad have been building together. going to be putting it in a short wide ‘00 truck.
correct me if I’m wrong, but my options are either to A, go to the junkyard and get a drive by wire pedal with the module it attaches to
or B, get a drive by cable throttle body. This seems easier but the harnesses are different, right? Wondering what wiring needs to be modified if I go with a DBC intake swap rather than doing all the DBW conversion stuff.
i should mention I really want to keep it DBC. just prefer how that setup feels.
thanks for the help and point me to any helpful threads if I didn’t catch this question already answered.
Old 08-19-2024, 07:26 AM
joom's Avatar
https://www.performancetrucks.net/fo...-guide-378643/
Old 08-19-2024, 09:02 AM
shakenfake's Avatar
Received 1,276 Likes on 973 Posts
You just need to put the DBC throttle body on it.
Harnesses are the same for the most part. You don't need to change anything when using a 99-02 harness.
that_1_arkansan (08-20-2024)
Old 08-20-2024, 08:53 AM
Registered User
I’m not sure what year the 4.8 came out of as I was given it by a relative, but seeing as it’s DBW it’s an 03-06. So what you’re saying is I just need to either buy or go to the scrapyard for a 99-02 v8 harness, and then hook it up to the 4.8 when it’s mounted in?
do I need a 99-02 ecu with the drive by cable stuff inside of it? I’ve seen there’s some differences where the newer computer doesn’t have the cable module.
Old 08-20-2024, 09:29 AM
shakenfake's Avatar
The PCM that you have with your V6 will work.
Yes you need a 99-02 harness and fusebox and not the 03-06. It will make your life wayyyy easier
Old 08-20-2024, 10:54 AM
strutaeng's Avatar
Is your V6 computer the 0411-style that looks like aluminum or the black box?
My 99 Silverado V6 had the black box, so I got the other style when I did my V8 swap.
Old 08-20-2024, 01:18 PM
Registered User
had to go outside and check it’s a black box
is there an advantage between the two?
Old 08-20-2024, 01:20 PM
Registered User
Yes that’s exactly what I want to do, make this as easy as plug and play, because I know I messed up picking this year truck with this newer engine but the engine was only $500 bucks from him and the truck was cheaper than what 03-07’s are going for. I like the bubble eye look a lot too! It already came with an HD conversion when I bought it.
Old 08-20-2024, 01:34 PM
shakenfake's Avatar
Okay then since you have a black box you will need the PCM out of any 99-02 V8 truck. V6 will work as well you just need the correct one.
strutaeng (08-20-2024)
Old 08-20-2024, 01:36 PM
Registered User
okay I’ll add that to the junkyard run, just the throttle body, I need the v8 motor mounts and a 99-02 harness. And an aluminum 99-02 v8 PCM. Thanks dude.
The following 2 users liked this post by that_1_arkansan:
shakenfake (08-20-2024), strutaeng (08-20-2024)
Quick Reply: V8 SWAP couple of questions
