Vacuum Leak??
Old 11-02-2009, 06:09 PM
Ender06's Avatar
Default Vacuum Leak??
So how is the best way to find a vacuum leak?? My tuner says that is most likely my problem. It has a hard time idleing. And it seems to have happened after I installed the injectors. I made my own spacers, maybe I made one too tall, I dont know. Any clue what to do?? it may be something else, idk
Old 11-02-2009, 07:16 PM
Grumpy5.3's Avatar
pour water on the intake where it meets the head while you have the engne running. You will be able to tell if you have one, by the misfire getting worse or hearing a gurgling sound.
Old 11-02-2009, 07:18 PM
Wearin' da big hat
00ChevyScott's Avatar
Thats a stupid idea.
Use some sort of starting fluid and spray around where you suspect a leak. If there is a leak, the idle should change quickly.
Old 11-02-2009, 07:20 PM
Ender06's Avatar
I will DEFINETELY try this, thanks Scott!!
Old 11-02-2009, 07:35 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Carb/choke cleaner works well for this also. Don't use brake/parts cleaner.
Old 11-02-2009, 07:42 PM
Ender06's Avatar
You remember what happened LAST time with the carb cleaner and the mower, right??? lol
Old 11-02-2009, 08:02 PM
Grumpy5.3's Avatar
Why exactly is water a stupid idea you little ****??? Same thing happens when water finds the leak, as starting fluid. and its free!!
You know you always got some smart *** answers for stuff. Works good for me and all the guys I know... assclown!
Old 11-02-2009, 08:08 PM
hirdlej's Avatar
+1 - I prefer this method as it doesn't use chemicals that harm ruuber/paint.
Old 11-02-2009, 08:10 PM
I wouldn't use water either.
Old 11-02-2009, 08:46 PM
Grumpy5.3's Avatar
1 good reason why????? please, tell me how it is stupid?
Quick Reply: Vacuum Leak??
