Valve float STS
#21
Originally Posted by hotrod04
Allen Nelson has sent me 3 pcm's and the forth on the way??
#22
There is talk of boosted valve float on this page here.
Three quarters of the way down. "Is choosing the right valve springs for Supercharged engines critical?"
#23
I AM A MOTHERF*CKER
Don't know how you check the IATs and I have the filter that sts supplies with there kit. Xtreme say's there is no KR. Could I check it out without the Air filter for just a short drive?
Xtreme is most likely logging the IATs. If you are still working on the tune, make sure Allen knows about this issue. I highly doubt its valve float. I spun my stock motor up to 12psi with no float.
#24
According to that article, because of the 5 psi he is pushing, his seat pressure is reduced by around 20lbs. I wouldnt think that would be enough to cause valve float, especially at only 5000rpm....I still think it is in the tune. I dunno, you should talk to one of the sponsors here. They could give you a definite answer.
