Valve spring swap help!!!
The cam is in, it was so easy I couldn't believe it. Anyway I'm replacing the springs doing the TDC method and one of the valves doesn't stay up so I can't install the locks as the spring can't be compressed any more.
Tried to put some grease around the valve stem to see if it sticks out but the ****** keeps going down.
Other than an air spring compressor, what can I do?
PT's Slowest Truck
Originally Posted by 1Bear
If you don't have air, you can do the old shade tree method of pulling the spark plug, feeding in some small rope through the spark plug hole and rotate the motor up to TDC compressing the rope up against the valves in that cylinder.
Wearin' da big hat
Top dead center method
This method requires you to put the piston at the highest position in the bore, so that when you start to compress the spring, the valve can only drop until it hits the piston. When the piston is at top dead center, the valve can't move very far at all.
There are several ways to accomplish this:
A) You can place a small stick/rod/straw/something into the spark plug hole and have a buddy turn the crankshaft by putting the stock 24mm crank pulley bolt in and turning the bolt with a wrench. You should be able to feel when the piston comes up to the top.
B) This method is a bit more elegant. Rotate your motor over by hand until your cam gear and crank gear are dot to dot like you set them up as earlier. At this position, piston 1 and 6 should be at top dead center. You can change the 4 springs on these 2 cylinders now using the instructions below. After you change those 4, then, rotate the crankshaft a full 90 degrees, and the cam gear dot will turn 45 degrees, as if it is pointing to 7:30 if it were a clock. Now piston 8 and 5 are at the top and can be changed. Rotate another 90 degrees on the crank and your cam gear dot will now be at 9 o'clock. Piston 7 and 4 can now have their springs changed. And FINALLY, rotate the crank another 90 degrees and the cam gear dot will be at 10:30. You can now change your remaining four springs on piston 3 and 2.
Once again, that's 1 & 6, rotate 90, 8 & 5, rotate 90, 7 & 4, rotate 90, 3 & 2.
