valve springs
Old 05-18-2005 | 12:14 AM
black4x4's Avatar
Default valve springs
Witch would you guys personaly run for springs on a vinci 062 cam comp 918s or the crane dual ones?
Old 05-18-2005 | 01:19 AM
gonzo 6.2's Avatar
You might have better luck getting a response if you put in the cam specs or a direct link to that cam.
Old 05-18-2005 | 06:23 AM
tdrumm's Avatar
210/218 @.050, .551/.551, 112
FWIW, I'm going to run the Crane duals, which are good for .600 lift with that cam. I choose them because 1.) they are from the same manufacturer so they are designed to work together, especially if I add their 1.8 rockers later, 2.) There's a slight safety factor against dropping a valve should one of the springs break, 3.) They are supposed to be one of the quietest springs, which was important to me.
Old 05-18-2005 | 07:13 AM
FILE's Avatar
No need for dual. the comp 918 should work perfect in there. EVen the 02+ ls6 will work in there.
Old 05-18-2005 | 06:52 PM
bigredexpress99's Avatar
Not to jack your thread, but how noisy are the 918s compared to the stock ones and duals?
Old 05-18-2005 | 07:12 PM
budhayes3's Avatar
PT's Slowest Truck
My 915's, which have less seat pressure than the 918's, sound like a sewing machine...it's not overwhelmingly loud, but you can hear it, especially if you're listening for it.
Old 05-18-2005 | 07:14 PM
desTRUCKtive's Avatar
i vote 918
hmm, so the crane's dual spring design quiets them down? Getting ready to port/polish and upgrade a set of heads here and since I'm gonna be cammin it soon, looking into aftermarket springs.
Old 05-18-2005 | 08:39 PM
99Silver6.0's Avatar
The Cranes have the same seat pressure as the 918's so they will sound the same.
Old 05-18-2005 | 08:51 PM
ok, thanks.
Quick Reply: valve springs
