Valve Stem Seals for 2002 Silveradio 5.3 Engine?
Hi Guys! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
I have a 2002 Silverado with a 5.3 engine.It has 3,889 miles on truck.
If it idles for two or three minutes and you blip the throttle it smokes whitish blue smoke out the tail pipe. It wont smoke if it sets overnight. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Before you say why don't you take it to a dealer here is why. They say it is normal and it doesn't use enough oil to have work performed on it. They say also that it is more than likely unburned fuel. My truck uses about a quart of oil in 3,000 miles. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
I don't mind a whole lot 1 quart in 3,000 miles but I can see it smoking and this just kills me, it is embarrassing also. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Do you know of any aftermarket companies that makes valve stem seals for the 5.3 engine yet. <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
I talked to a dealer they said that the valve stem seals on a 2001 was 14mm and the ones on a 2002 are 22mm so they wont interchange. I think it is the type valve stem seals they use that is causing my truck smoke. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Do you guys have any ideas or suggestions??
I will just pay someone to put on the valve stem seals myself if you think this will fix it.
Thanks Lee!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
You guys have any ideas!
Re: Valve Stem Seals for 2002 Silveradio 5.3 Engine?
This "it's normal" attitude of GM is starting to bug me. <img border="0" alt="[fight]" title="" src="graemlins/gr_punch.gif" /> My rear 3rd door window was making noise and I thought they might tell me that was normal too. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> I would say that you may need more break in time but then again it sure as hell should not be smoking.
I hate to say it but you may have one of those motors that are out of tolerance. Does it knock, slap or tick first thing in the morning or after sitting a bit? That and oil use is one of the first signs of trouble. Monitor the oil usage. I have heard of guys not making it to 3000 and the low oil light comes on. Sure enough they were big time low.
FormerVendor
Gee, a quart every 3000 miles doesn't sound too bad. The smoke would definitely **** me off though. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
The earlier seals don't have the spring base built into them. If you switch the seals to GM#12533586 for intake and #12457652 for exhaust you will also need to obtain the earlier style spring bases. I don't have a part number for the spring base, but if you email me I'll gladly give you a set. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Hope this helps,
Richard <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Hope this helps,
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by JS-Z71:
<strong> My rear 3rd door window was making noise and I thought they might tell me that was normal too.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Here is the TSB for that on the 2000's
Quarter Glass - Wind Noise
File In Section: 08 - Body and Accessories
Bulletin No.: 99-08-48-001A
Date: September, 2000
Subject:
Wind Noise from Body Side Quarter Window (Replace Body Side Quarter Window Assembly)
Models:
1999-2000 Chevrolet and GMC C/K Extended Cab Pickup Models (Silverado and Sierra) Built Prior to February 1, 2000
This bulletin is being revised to add the 2000 model year, remove service procedures, and change the part numbers. Please discard Corporate Bulletin Number 99-08-48-01 (Section 08 - Body and Accessories).
Condition
Some customers may comment on wind noise coming from either of the body side quarter windows while driving with the quarter windows closed. The wind noise may be more noticeable at speeds over 56 km/h (35 mph).
Cause
An insufficient seal of the window frame to the body or an improper window latch length may cause this condition.
<small>[ September 27, 2002, 10:53 AM: Message edited by: Fast4.8 ]</small>
Subject:
Models:
Condition
Cause
Hi Guys!
I forgot to ask you there are 5 holes in the dip stick on a 5.3 engine. Does from the top hole on the dip stick down to the add oil part on the dip stick, does this mean when you get down to the add oil part of the dip stick, you need to add a quart of oil?
bsgiffor
07-19-2015 11:14 AM
