Valves
Originally Posted by 02denali
ooops my bad---2.04 and 1.575 is what they are going to be. i have heard that going to big it will shroud the piston or something like that. i am also getting 10.9-1 compression to.
ok ok. it is jay at absolute speed. he has done heads for a lot of people here on the board that are very satisfied with his work. i told him exactly what i had and my plans. i found an email that he sent me with his opinion. 2.00 and 1.57 is what they are going to be. he said that it would be set up perfect for the nos and the cam and rockers i am running. now that i have it right. what do you think.
Originally Posted by 02Reaper
Wow, I dont think that is going to work so good. I mean, how much bigger do you have to go to shroud the valves? a 2.00" valve on the stock 4.8/5.3 valve has to be deshrouded to work and even then, it is still pretty shrouded in there. Did you tell the guy that was doing your heads that this was for a 3.78" bore and not a 3.90" bore like on the 5.7"s? If you did, then I really dont think this guy has a clue as to what he is working with. Not to try to **** you off or anything, but I would expect your truck to be a real dog without the nitrous. Good luck man, keep us updated on how it works out for you.
Originally Posted by hink9
the stock valve sizes on a 5.3l head is 1.89 int, and 1.55 exh, so youre saying that with a 3.78 bore i shouldnt go bigger that a 2.0 valve? im just curious since vhp said that a 2.05 int valve would be good, but i dont think they knew i had a 5.3l.
well. darnit. i meant yes. hes saying stay smaller than a 2.00 valve
Originally Posted by SportSide 5.3
nah hes sayin smaller than 2.0
Wow, great picture Wess. I'm startin to see eye to eye with you now. Seems shrouding would really take affect with those size valves on such a small bore like we have. Am I wrong?
If some of you guys are lost by the word shrouding. Look at the pic. See how close the cylinder wall is to the outside edges (left and right) of the valves. This can limit airflow.
im doing some research and all im getting is 5.3l heads have 1.89 int valves stock,http://www.smokemup.com/tech/ls1.php whick means that an upgrade to 2.0's would be a good idea, or maybe some shaved 6.0l heads.
https://ls1tech.com/forums/showthread.php?t=145060
If you have a 3.90" bore engine then a 6.0L head does not flow like a LS6 head due to the air coming out into the as cast 4.00" size chamber of the 6.0L casting and then hitting the top of the bore, inducing turbulence. This and the fact that a 6.0L casting is 70cc and only yields about 9.5:1 compression is why PP decided to weld the castings they have to the smaller bore. Take my Stg 2.5 LS6 heads, on a 4.00 bore they flow 325 @ .600" on a 3.90" they still flow 320 @ .600", the same program in a 6.0L head flowed 324 @ .600" but on a 3.90" bore they only flowed 309 @ .600", all of this was flowed in house on our bench. So you can see how having the chamber diameter bigger then the bore hurts the airflow.
If you have a 4.00" or bigger bore engine then it doesn't make sense to weld up the chambers to the smaller diameter, just to have to port it out to 4.00" diameter where it needs to be. If a head can be milled a small amount to achieve a desired compression ratio then that is the way to go. So in short, get some 6.0L heads, we have new cores for $400 a pair, and mill them .018" to get to the 67cc that you need. There will be no problems milling these heads this amount, we mill practically every head we do at least this much. And it doesn't make sense to buy LS6 heads only to have to port the chambers out to a 4.00" bore and try to make them 67cc. Hope this helps.
https://ls1tech.com/forums/showthread.php?t=138650
They will sorta fit but not give accurate numbers. If you plan on running a set of heads on a 3.90" bore then flow it on a 3.90" bore.
For example
our Stg 2.5 6.0L/LS6 intake program on a LS6 head with the stock 3.90" bore chamber flows 325 @.600" on a 4.00" bore and 320 on a 3.90" bore- only a loss of 5cfm
The 6.0L head with the same exact everything flows 324 @ .600" on the 4.00" bore but only 309 @ .600" on the 3.90"- a loss of 15 cfm
so you can see if you flow a head with a chamber that is bigger then the bore you flow it on then it is very ditrimental to the flow, so you may not get the full answer if you port and flow LS1 heads on a 4.00" bore fixture. Hope this helps. Brian
https://ls1tech.com/forums/showthread.php?t=126951
If the chambers are not properly opened up to the 3.900" bore (they are 3.800" stock) a 2.00" valve would be too big. We do these with anywhere from a 2.02-2.05 intake and a 1.55-1.57 exhaust. My car went 9's on the spray with just a 2.02 and the stock exhaust valves of 1.55
We do the CNC porting of these heads at around $699 per pair, that includes the entire intake port, exhaust port and combustion chamber. Hope this helps.
__________________
http://www.totalengineairflow.com
__________________
