Valves
Old 09-05-2004 | 03:26 PM
  #21
hink9's Avatar
thats great info, i just dont understand what im reading lol,
Old 09-05-2004 | 03:32 PM
  #22
02Reaper's Avatar
Originally Posted by SportSide 5.3
Reaper,
The set Allan is working for you now, did he suggest stock valve diameter, or was that your choice? Is he in the process of working them now?
Thanks,
Kyle
I suggested the stock diameter. I have talked to him numerous times on heads for these trucks. He basically said that the trucks dont gain really from going all out on the porting. He is working on them right now, so hopefully I will have them within the next couple of weeks.
Old 09-05-2004 | 03:41 PM
  #23
02Reaper's Avatar
Take a look at this picture and look at how the air has to travel around the outside of the valve between the valve and the cylinder wall. If It cant flow between the outside of the valve and the cylinder wall, you create turbulance, which hurts flow. Think about trying to blow through a straw with your mouth wide open. It doesn't work too good does it. It works a whole lot better if your lips are the same diameter of the straw. That is velocity.
http://www.mitsubishi-motors.co.jp/i...derAirflow.gif
Old 09-05-2004 | 03:46 PM
  #24
Texas Terminator's Avatar
11 Second Club
Old 09-05-2004 | 03:55 PM
  #25
Sport Side's Avatar
Damn, nice diagram. Hink, pay attention to the right video, more accurate of an ls1 except for the spark plug.
Valve size does play a part in velocity, correct? And shrouding would be slowing down the flow as the air/fuel try to go around the valve. Would that be wrong?
Texas, what are the valve specs, what you would recommend?
Old 09-05-2004 | 04:30 PM
  #26
11 Second Club
Texas, what are the valve specs, what you would recommend?[/QUOTE]
what else do you want to know? they are 2.02 intake and 1.65 exhaust stainless ferrea valves in modified (obviously) 6.0L heads. i also had them polydyne coated. as far as a recommendation, you need to figure out what kind of setup you are going to end up with. will it be forced induction? spray? N/A? what kind of cam profile? what C/R? what kind of flow numbers are you looking for? what kind of porting will be done to the heads? there are several factors.
Old 09-05-2004 | 04:49 PM
  #27
Sport Side's Avatar
My mistake. I didn't realize you were responding to original topic when I read your first post.
Thanks for including the factors that deal with how to decide upon the correct valve sizes. Would you mind sharing details on how compression ratio/flow numbers/cam profile tie into valve size?
Old 09-05-2004 | 05:12 PM
  #28
one03sierra's Avatar
Formerly one92rs
Talking
so basically any valves over 1.90 let's say are overkill on intake and anything over 1.55 on exhaust is the same.
Old 09-05-2004 | 07:48 PM
  #29
Sport Side's Avatar
What is it, a 75% exhaust to intake ratio that seems to make the best results? How do you come up with this ratio? Can you just compare valve sizes to find this ratio?
Any guidance would be appreciated
edited: exhaust to intake , not intake to exhaust.
Old 09-05-2004 | 07:50 PM
  #30
02Reaper's Avatar
On the 3.78" bore. Yes
Here is someone else who also thinks so.
http://forum.ls1truck.com/index.php?showtopic=2524
Quick Reply: Valves
