Valves
Old 09-05-2004 | 09:06 PM
  #31
02Reaper's Avatar
Originally Posted by SportSide 5.3
What is it, a 75% exhaust to intake ratio that seems to make the best results? How do you come up with this ratio? Can you just compare valve sizes to find this ratio?
Any guidance would be appreciated
edited: exhaust to intake , not intake to exhaust.
Well, I really dont know how they figure that. I am just not in it that deep, but to answer your question a 75% exhaust to intake ratio on our heads would be a 1.89 intake and 1.42 exhaust valve. On the other ls1 heads, it would be 2.00" intake and 1.50" exhaust. Right now we have 82% intake to exhaust ratio and the other ls1 heads have 77 1/2% intake to exhaust ratio.
Old 09-06-2004 | 12:19 PM
  #32
Sport Side's Avatar
If the ex-in. ratio is found by comparing valves then your correct. But,
I'm thinking it may be found by the flow numbers. If it is by valve diameter, then it would make since why 2.02in,1.57ex, is popular amung the 346 crowd, where there keeping the stock 77.5% ratio by upping diameter by .02 on in., and ex.
maybe b.t. knows
btw, if you come back texas and missed my question to your post, would you mind helping heres question:
Would you mind sharing details on how compression ratio/flow numbers/cam profile tie into valve size?
Wolftrk99
12-03-2015 08:12 PM
00loudchevy
12-03-2015 05:54 PM
Avalanche2002
11-30-2015 07:31 AM
JordanH
10-03-2015 03:59 PM
Velocity1
10-02-2015 08:01 AM
Quick Reply: Valves
