The VaraRam King Cobra induction is coming soon!!
This system will be over 100% efficient compared to about 80% for some other systems.
The high pickup will located in the upper grill with a 3:1 multiplier.
Water trough system can drain up to 1 gallon of water every 30 seconds! This will allow you to drive your truck like a truck!
A 3 layer washable, reusable filter that allows flow of up to 1000cfm.
No drilling or cutting required for the install.
Designed to be used with the VR Velocity Stack.
This system is capable of building 1 pound of pressure at only 60 MPH.
This induction will be available as shown or with a ram air tube that will have cold air forced into it at speed. This will give it a pretty direct shot right into the filter. I'll have some more pictures and info soon!
Tom
Order line - 1-877-4-TBYRNE
E-mail - tbyrne@tbyrne.com
Installation services available!
The version without the ram air will be about $249. This will cover all of the 1999-'04 GM trucks and SUVs. There will also be a system for the 1996-'99 5.0 and 5.7 motors.
VaraRam will guarantee at least a 5 tenth improvement in your 0-60 times. They have actually seen better improvements on some trucks in testing.
14 Second Truck Club
My friend used to try out the VaraRam products before they came out and he said that the intake wasn't all that great. He also said that they may have changed it a little since he last had it so I don't know.
I think i like the filter housing with it. If you point it down and add some 5" tubing down to where the air dam is you could make a real easy and nice ram air set up. I wish i had the money to actually build and market some of my ideas. I know i'd sell most of them like crazy. I'd be so deep in money i could build a fleet of 10 second shop trucks. OK, so im dreaming.
It looks like a nice setup with real potential after some minor modification.
