Vic Jr guys...where did you put your MAP sensor?
High on diesel fumes
I'm not 100% sure, but I think it's either that, a problem with the stock fuel rails getting some junk in them and temporarily clogging an injector, or my wideband reading incorrectly because it was too close to the turbo outlet. I'm going to solve all three potential problems with a Vic Jr, billet fuel rails, and a relocated wideband sensor.
there is also a small 1/8 npt port on the passenger side of the intake right where the carb pad is
if you have cathedral ports id go with the super vic, it has larger runners but a higher carb mount
Post #97 is how Parish ran his...
https://www.performancetrucks.net/fo...=371574&page=3
If you going to use the 4bbrl TB, then you could use an aluminum carb spacer and install some vacuum fittings in it, similar to the elbow Parish used...
Good Luck
Good Luck
GFYS and STFU
Offtopic again but where is his thread where he sold it? I was looking through his posts and couldn't find it?
Sorry for the offtopic Chris, my camera is busted so I can't take a pic of my set-up.
