victor jr swap questions
what is the sensor that i have in picture two ? it has a spot where it goes into the intake and has tha those with the test port comign off of it. i saw parish's thread where he tapped the back of his elbow. that should work but i still dont know how to mount the sensor. i guess i could do a hose and put it in there.
9 Second Club
It's the EVAP that vents the fuel tank through the intake to keep the fumes from going straight into the atmosphere. I pulled the EVAP sensor out of the intake, and put a hose on the bottom of it, routed under the manifold and Tee-d into the brake booster hose. You could delete the EVAP if you wanted also.
no id like to keep it. i understand what you did. now i was reading on parish's thread on how he put a check valve on the brake booster , someone said that having the brake booster line comign from the intake rear runner could cause that cylinder to get rice. now dont the brake booster have a stock check valve? or should i put one on it to be safe? i could also just plug that hole and tap the brake booster into the back of the intake elbow where parish tapped all of his vacum lines
