victor jr swap questions
Old 05-25-2007, 08:07 PM
  #21
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Where did you get the o-rings for the manifold, GM wants almost 40 bucks for 8 damn orings for the intake.
  #22
11 Second Club
Phantom's Avatar
actually i take that back... email Aaron@IntakeElbows.com thats who i talked to...he was going to hook me up on my elbow before i backed out on him....if i can find my emails i'll send them to you
Old 05-25-2007, 10:07 PM
  #23
8 Second Truck Club
Blown06's Avatar
Hear is what I did:
MAP Sensor: Pull the orange rubber gromet off and it will reveal a barb type fitting, hose clamp vaccum line from there to a spot in the intake.
Brake Booster Hose: Buy a barb fitting to thread into the runner on the intake and connect. The brake booster has a one-way check valve in it already, you can try to blow through it and see.
EVAP Sensor: I deleted mine, however if you want to keep it, just hose clamp vaccum line to it, and run to a spot on the intake.
Vaccum lines from each valve cover: I bought a Moroso Crank Case Breather Tank and welded two pieces of 3/8" aluminum fuel line on the side opposite of the -12 fitting. Run each valve cover hose to this tank, and run a -12 line to the intake side of your Vortech. This helps create vaccum in the crank case which is a good thing, especially under boost. Or if you want you can plug the -12 fitting and run it as is.
Old 05-26-2007, 03:34 AM
  #24
2004SSS's Avatar
well right now i have a a barb type fitting on my blower piping( pre blower) and i am thinking of just running a hose from that to a tee fitting then to each valve cover. right now i really feel like dropping the evap , i have so many dam vacuum lines i need to run , one for the bov, brake booster, two for the pcv , hobbs switch on for the 2nd pump, meth map sensor, evap, boost gauge, 2 bar map , and i am sure there are more i cant think of. im thinking i shoul dhave it dam close to firing tommorrow.
Old 05-26-2007, 03:35 AM
  #25
2004SSS's Avatar
dude i had to buy two sets( for vic jr and my camaro) i didnt think they cost that much either
Old 05-26-2007, 08:23 AM
  #26
does any one have any pictures of these set ups?
Old 05-26-2007, 11:05 AM
  #27
2004SSS's Avatar
yes
ill have more pics up today with an almost finshed motor i hope
Old 05-27-2007, 05:49 PM
  #28
negativeswitches's Avatar
do you have to use car inj. with the vic jr?
how did you relocate your battery upthere?
Old 05-27-2007, 05:55 PM
  #29
2004SSS's Avatar
relocating it was easy just got some 1/0 gauge cable and ran it from the the fuse block and to the starter . ground it to the frame and ran som e4 gauge to the alt. i got an hd battery tray from a 2500 hd to relocate it.
yes you need car injectors for this intake and rails.
Old 05-27-2007, 05:58 PM
  #30
"i got an hd battery tray from a 2500 hd to relocate it."
thats what i was lookign for
thanks
creekrat
08-02-2015 01:27 AM
USMCvet0311
08-01-2015 07:45 AM
steves86ta
07-28-2015 10:21 AM
WICK3DxGATA
07-21-2015 06:59 PM
Quick Reply: victor jr swap questions
