video - tranny slipping?
Old 10-12-2004 | 06:00 PM
one03sierra's Avatar
Formerly one92rs
Talking
unless it is locking at the shift. then i guess it would do exactly that.
Old 10-12-2004 | 07:20 PM
BlownChevy's Avatar
blownerator
Sounds tune related to me. Put the superchips tune back in and see if it still does it.
Old 10-12-2004 | 07:38 PM
Flyer's Avatar
I'm thinking tune too. The converter does lock right then in stock program, I don't know what Allen's doing with it though. It will feel similar to how that sounds, but it shouldnt loose rpm or momentum like that.
Old 10-12-2004 | 07:39 PM
Flyer's Avatar
Theres not any way you can get ATAP or EFILIve on it is there?
Old 10-12-2004 | 08:01 PM
Dark Halo's Avatar
Originally Posted by O3GMC
Yes, when it downshifts into 3rd at WOT it does it. Haven't tried in OD, it downshifts too easily and to be going WOT at 4k rpm in OD, that would be going pretty fast....my driveshaft (I think its the driveshaft) starts vibrating at around 115.
Sicne 3rd sees the most hp/tq - maybe its the clutch pack slipping? Fuel pressure is fine - but could it be the tune? I'll show it to Allen and see what he says.
I feel dumb asking this, but how can you tell when the converter is locked or not?
I didn't mean WOT in od I just me when the truck in in od and then downshifts to 3rd. Sorry for any confussion. This is the same problem I have.
Old 10-12-2004 | 08:06 PM
budhayes3's Avatar
PT's Slowest Truck
My truck seemed to do something very similar right after I installed the cam, but in 2nd gear and 3rd gear, right after the shift. After installing the Vinci tune, it went away. Methinks a tune might cure what ails ya.
Old 10-12-2004 | 08:11 PM
Dark Halo's Avatar
what would the lock speed need to be set to in order to cure this problem?
Old 10-12-2004 | 08:15 PM
Flyer's Avatar
Set the lockup speed to 255 for 100% throttle.
Old 10-12-2004 | 08:24 PM
StupidFast's Avatar
Thats the converter locking up. It locks up at 75 stock and at 100 with the hypertech.
Try pressing the brake pedal slightly, it should disengage the TCC. I not sure if it will work at full throttle.
Old 10-12-2004 | 09:23 PM
F8L Z71's Avatar
Wierd that it happens right around peak TQ. Or is it really that weird after all?
Quick Reply: video - tranny slipping?
