Volant induction special
Volant Cool Air Intake Systems are revolutionizing the way a true COLD air intake should be manufactured. Volant engineers each vehicle application to give the customer a quality intake that fits and installs like OEM. Volant modifies the air intake duct and filter box by reducing intake restrictions, rerouting and increasing the diameter of the new air duct without removing any OEM sensors from the vehicle. All intake systems are molded with a high-grade X-Link polyethylene material to insulate the air box from conducting as much heat as would metal.
The design of this system opens up the air flow, but still maintains that smooth sound by keeping the same resonator box style that the stock duct has in order to reserve the air for that off the line quick take off. They also increased the diameter duct and gained up to 12 hp and 19 lbs of torque.
15853 1999-'04 4.8, 5.3 and 6.0 Silverado and Sierra $239.99
15953 1999-'04 5.3 and 6.0 Suburban, Yukon, Tahoe, Escalade, Avalanche and Denali $239.99
15881 2001-'04 8.1 Silverado HD, Sierra, Suburban and Avalanche $239.99
1500 series owners can add a scoop to their order for $119.99 -
Add-On Scoop: Cross-link polyethylene air scoop attaches to the Volant box to create an additional air flow from outside the engine compartment.
High Performance Silicone Connectors: High performance silicone hose connectors provides flexibility while maintains strength and thermal stability.
Stainless Steal Clamps: Marine grade clamps allows optimal performance with large operating range and available for virtually any application which requires maintainability and versatility.
This sale will be ending on Sunday evening (12/19).
Tom
gaps
10-15-2015 02:53 PM
69z-28
09-21-2015 07:31 AM
FlowmasterMufflers
09-18-2015 02:31 PM
