Voltage drop at WOT
Old 06-21-2009, 09:36 PM
oldred95's Avatar
Up until my stock alternators death at 193,000 miles it never had a drop issue at WOT. I switched from the small case CS130 to the big case CS140 and noticed the WOT voltage drop right off. Its like the alternator was disconnected past 4500 rpms. It was very noticable with the head lights on. Honestly I haven't paid attnention to it lately but I haven't noticed it doing it. Then again I haven't driven at night much either to see it in the lights as they dim. I'm clueless as to what it is. The alternator works great otherwise.
Old 06-22-2009, 12:04 AM
marlboroman71818's Avatar
Not saying that it is belt slip or or is, but he could still be experiencing full boost and the belt slipping on the alternator also. Can you manually select a gear and use part throttle thru the rpm range and see if it is slipping. If it does not stop charging then I would say it is belt slip, If it does stop charging then I would say you have a different problem.
Old 06-24-2009, 09:40 PM
High on diesel fumes
thunder550's Avatar
Swapped alternators, still does it. I have a tighter belt coming on Friday, so we'll see if that solves it.
Old 07-14-2009, 01:22 AM
thunder550's Avatar
Tighter belt didn't help. Seems to be RPM related....WOT at lower RPM doesn't do it but once it gets up higher it does. Any other ideas?
Old 07-14-2009, 05:58 AM
dhpro's Avatar
E-fans? Maybe try underdriving ur alternator...cud be it just doesnt like the torque/rpm at that range...hook up tuning software and get some feedback. Ask an elec engineer like DrX (Grant), he might have an idea...I've had voltage bounce ever since I put e-fans on. I put a 145amp in and did the Big 3 wire upgrade and it helped, but no cure ($250 later). R/
Old 07-14-2009, 06:38 AM
oldred95's Avatar
I used the stock length belt when I put my CS144 on which actually made it a little tighter. The tension has to travel back a little further then original and the spring has got some serious tension on it at that point. I'm like you, I don't think its belt slip. The belt isn't glazed or burnt looking at all. I think it may be something with the regulator. Maybe it can't keep the voltage under control and it shuts off until the rpms come back down. I know mine happened right around 4500 rpms. It was like a switch was flipped and it stopped charging. I haven't noticed it so much lately but with my new cam I will be shifting at 6000-6200 so if its still doing it I bet I notice it a lot more.
Old 07-14-2009, 08:49 AM
SPAM HUNTER
2005 Silverado's Avatar
Try a little looser belt, see if the belt tension is to tight and causing a bind when spinning it up high.
Dustin
Old 07-14-2009, 09:10 AM
Resident Retard
BlackGMC's Avatar
Mine was doing something similar, when I had the battery checked and it was bad. Not bad enough to cuase the truck not to start but bad enough when it was a large load the volts would drop. Just stop by autozone and have them check it real quick.
Old 07-14-2009, 09:50 AM
LaSinister's Avatar
Just an Idea, but maybe its the wire that goes from the alternator to the junction block that is somehow corroted?? Maybe it can't handle peak current at those high RPMs.
Old 07-14-2009, 10:02 AM
skeet's Avatar
chris check your spark plug wires, make sure all 8 of them are seated, ( snapped all the way on) i just went through this.
Quick Reply: Voltage drop at WOT
