Vortech supercharger and a set of AS+M long tube headers for $3749.
Old 12-02-2003 | 11:59 AM
tbyrne's Avatar
Default Vortech supercharger and a set of AS+M long tube headers for $3749.
We are offering the satin finish 4.8, 5.3 and 6.0 Vortech truck supercharger with a set of AS+M long tube headers for $3749.99. Add $250. if you would like to go with the polished instead. This is a very good way to bolt-on over $125 horsepower.
The Vortech supercharging system for the 4.8/ 5.3/6.0 GM light truck will impress you with the obvious attention to detail and fully integrated appearance. Increase your horsepower to 391 and torque to 420 ft/lbs (5.3 Engines) to help you pull you, your passengers and your toys over the hill or around the corner.
Includes V-2 SQ S-Trim supercharger
Satin or Polish finish
Hand-held programmer controls ignition timing and fuel enrichment
OEM style cast aluminum supercharger mounting bracket
Cast aluminum discharge tube with Bosch compressor bypass valve
Molded inlet duct retains stock air box and MAF locations
Oil drain, oil feed, and air intake assemblies
The Vortech supercharging system for the 2002 4.8 GM light truck will impress you with the obvious attention to detail and fully integrated appearance. Increase your horsepower from 275 to 371 and torque from 290 to 377 ft/lbs to help you pull you, your passengers and your toys over the hill or around the corner. Please note that Vortech does not offer programming for alternatively fueled vehicles (trucks with a Z in the 8th digit of the VIN).
The Vortech supercharging system for the 2003 5.3 GM light truck will impress you with the obvious attention to detail and fully integrated appearance. Increase your horsepower to 370 and torque to 406 ft/lbs to help you pull you, your passengers and your toys over the hill or around the corner. Please note that Vortech does not offer programming for alternatively fueled vehicles (trucks with a Z in the 8th digit of the VIN).
The Vortech supercharging system for the 2002-2003 6.0 GM light truck will impress you with the obvious attention to detail and fully integrated appearance. Increase your horsepower from 300 to 415 and torque from 360 lb./ft. to 447 lb./ft. to help you pull you, your passengers and your toys over the hill or around the corner. Please note that Vortech does not offer programming for alternatively fueled vehicles (trucks with a Z in the 8th digit of the VIN).
Arizona Speed and Marine has taken the time to ensure that these are the best headers for the newest GM truck. Extreme effort was put forth towards proper fitment, durability, and performance. They have produced gains of 22 horsepower and 25 ft./lbs. of torque on a stock 5.3L V-8. These exhaust headers are designed to work with all three V-8 engines; 4.8L, 5.3L and 6.0L. They will work on both two and four wheel drive. Features: 4.8L, 5.3L and 6.0L application; 1 3/4" Primary Tubes; HPC Ceramic Coated; Emissions Compatible; Laser cut flanges for accurate gasket seal; Includes headers, gaskets, bolts, and installation instructions. ** Does require some installation welding as documented in the installation instructions.
Orders can be placed online or by calling 1-877-4-TBYRNE.
Have a good day,
Tom
Old 12-02-2003 | 12:08 PM
Does Vortech make an intercooler for this system? Would an intercooler help?
Old 12-02-2003 | 12:23 PM
FILE's Avatar
Tom, make it a Radix without the headers for that price and I am in.
Old 12-02-2003 | 01:46 PM
tbyrne's Avatar
smokinRice: Yes, it just became available -
Vortech Engineering now has a supercharger with Aftercooler available for the 2003 Silverado SS, Cadillac Escalade and GMC Denali.
Kit details:
Flywheel horsepower/torque 6.0 Chevrolet SS truck:
stock (factory rating) ---345/380
supercharged (estimate based on % increase @ wheels)--- 465/494
Manifold boost pressure: 7-8 psig @ redline
Includes V2 S-trim supercharger with 3.33? driven pulley
Complete fuel system upgrade includes replacement fuel injectors, fuel lines and a high flow supplemental fuel pump with harness. Included hand-held programmer also controls ignition timing and fuel enrichment.
Molded air inlet ducting assembly features the Vortech logo, maintains factory appearance and employs the stock air box
Includes replacement engine coolant pipe and hose assembly
Oil drain and oil feed assemblies allow for maintenance free operation. Tools included for simple modification of oil pan for supercharger drain fitting installation
Factory appearing cast aluminum supercharger mounting bracket assembly includes idler, drive belt and all hardware
Air/water charge cooler system included. Charge cooler assembly includes:
a) Welded aluminum charge cooler core with discharge tubes, Bosch compressor bypass valve, silicone elbow, sleeves and stainless steel clamps
b) Charge cooler water storage tank with hoses, clamps and plumbing
c) Compact water circulation pump for closed loop cooling
d) Highly effective water cooler
Supercharger kit installation time is rated at 13-15 hours.
CARB E.O. D-213-19 has been assigned to this kit
It is strongly recommended an aftermarket transmission shift kit upgrade be installed.
We can also put something together for this kit and AS+Ms -
4GL218-080SQ 2003 6.0 with Aftercooler - Escalade, Denali, SS + AS+M headers $5279.99
4GL218-088SQ 2003 6.0 with polished finish with Aftercooler- Escalade, Denali, SS + AS+M headers $5379.99
Tiburon: Shoot me an e-mail. We have a KILLER deal for the Radix by itself!
Tom
www.tbyrnemotorsports.com
Old 12-02-2003 | 01:54 PM
Does that work with the 5.3's?
Old 12-02-2003 | 03:52 PM
Anybody notice that the reported Vortech performance numbers are the same with or without the aftercooler...
6.0L SilveradoSS: 345hp/380tq goes up to 465hp/494tq in both cases.
Is something wrong here? I thought Adam said he was getting like 505hp/517tq with the aftercooler on his Red SS.
Finally, if 505/517 is correct, is the extra $1500 for the aftercooler worth it for the extra 40hp/23tq you get?
Just contemplating various $/hp options...
Keep the good deals coming Tom!
Old 12-02-2003 | 04:17 PM
tbyrne's Avatar
Thanks for pointing that out. I found this morning that the new kit's part numbers and the horsepower/kit description was listed on the site but we weren't notified that it was the kit with the Aftercooler. Big -
The Aftercooler upgrade is usually about an extra $1500. for kits that can use it. It's along the same line as the increase that Magnuson had when they came out with their intercooled RADIX system. I think this will be a pretty popular system.
Physically I think it will bolt onto a 5.3 motor but they probably don't have programming for that yet.
Old 12-02-2003 | 06:08 PM
2nd Sierra's Avatar
yhm tom
Old 12-03-2003 | 01:41 PM
tbyrne's Avatar
I took me a few minutes to figure out yhm. Guess I need to sleep more
Old 12-03-2003 | 07:01 PM
2bseen's Avatar
11 Second Truck Club
how much for the new votech with aftercooler.
