Walbro 255 pump?
Old 10-01-2009, 12:03 AM
Black'Rado's Avatar
its not that bad...when i first pulled it apart it looked harder then i thought but it only took me like 45 min to do...hardest part is grinding the lip down on the inside of the bucket and cleaning it out
Old 10-01-2009, 09:01 PM
03lowriderss's Avatar
sticky material right here, ....mod
good right up black'rado
Old 10-01-2009, 10:05 PM
PT's Slowest Truck
budhayes3's Avatar
Excellent write up, I agree...Sticky! People ask about the Walbro install on a daily basis!
Old 10-02-2009, 09:57 AM
Black'Rado's Avatar
thanks...yea when i searched on the install i got was "the bucket needs modifying" but never exactly what needed to be done
Old 10-03-2009, 12:27 PM
ShredSled's Avatar
Hey, I appreciate you taking the time to shoot some photos and post them with the basic write up here. Big help! I'll be doing this in the near future and will definitely be referring back to this thread!
Looks like you did a great job.
I agree, sticky would be excellent.
Old 03-22-2010, 04:31 PM
11 Second Truck Club
MPFD's Avatar
Thats exactly the same way i did mine, and it failed on me in less then 500 miles. Anyone else have a Walbro failure. I went back to stock but with my new motor and spray I need another one. Was mine just a fluke or are others having failures?
Old 03-22-2010, 04:47 PM
Black'Rado's Avatar
ive been running mine hard since the install with zero problems except i didnt install a valve so i have to prime it about 2 seconds before i crank the truck....also a good rule of thumb is to never let the tank go to far past 1/4 because the fuel actually cools the pump and heat=bad for the pump.
Old 03-22-2010, 04:51 PM
Moderately Differentiated
dewmanshu's Avatar
fluke. I have an inline (which are prone to fail more often for some reason) and a walbro in tank. Walbro in tank has been there for a couple years now.
Old 03-22-2010, 05:01 PM
11 sec. Truck Mod
TIM Z's Avatar
Def . great thread. Thanks for the writeup!
Old 03-22-2010, 05:15 PM
Black'Rado's Avatar
One thing to add to this write up is if possible get a one way valve to install after the pump to keep pressure in the system....not totally necessary but help on startup!
maybe it will make sticky?
Quick Reply: Walbro 255 pump?
