Walbro 400lph good enough for turbo?
Old 11-20-2013, 12:16 PM
Noah Burns's Avatar
Ok, I'm not very wiring savy, what wire do you need from the factory harness to the relay? 12v source for power on pump, harness power supply turns on the relay?
And I guess might as well ask where the best place for the fuse would be in the 12v power line or on the pump side?
And what size fuse do most run with a pump like that?
Old 11-20-2013, 12:19 PM
I have a gauge for that
Atomic's Avatar
Read: https://www.performancetrucks.net/fo...p-flow-510434/
Old 11-20-2013, 12:36 PM
Ferocity02's Avatar
The factory wire that provides power to the pump will instead go to the relay and switch the relay on. Not sure which wire it is exactly, but it should be easy to figure out with a voltmeter or some searching on here.
Put the fuse between the battery and the relay.
Old 11-20-2013, 12:39 PM
timmay208's Avatar
Originally Posted by Ferocity02
And a fuse somewhere in there
not a bad idea
Old 11-20-2013, 12:42 PM
timmay208's Avatar
30amp fuse should be fine
your factory harness has a power that turns on the fuel pump, you wire that to the relay, so when it gets power the relay allows the 12v wire you ran from the battery to turn on the pump
like this
Old 11-20-2013, 12:54 PM
Noah Burns's Avatar
I guess a good question to ask right now would be, does this setup work with the FPCM on the NNBS trucks?
Guess it would really just go around it all together huh...
Old 11-20-2013, 12:57 PM
timmay208's Avatar
that i do not know
Old 11-20-2013, 05:35 PM
If your not wiring savvy just get a hotwire kit from Racetronix. I takes about 10 minutes to install if you already have the bed off.
Old 11-20-2013, 05:45 PM
Noah Burns's Avatar
I'm savy enough to figure this out I think... I was thinking it was going to be a lot more involved than it is honestly. Seems pretty dang straight forward really, going to put the main 12v power on a kill switch.
Old 11-20-2013, 06:36 PM
Atomic's Avatar
Good anti-theft idea
Put it on the low current side of the relays.
greedygenius
09-03-2015 06:51 AM
lxcoupe
07-21-2015 02:12 AM
GMCtrk
07-17-2015 06:39 PM
Deceptarado
07-08-2015 05:24 PM
Quick Reply: Walbro 400lph good enough for turbo?
