want to make 400 whp with 6.0
Old 07-30-2012, 05:27 AM
  #21
chevybuilder383's Avatar
Originally Posted by 2doorfury
there the same, put some 8.1 injectors in. they are a direct swap
what is the flow rating of the 8.1 injector
Old 07-30-2012, 06:26 AM
  #22
iamkeniff's Avatar
Stock 8.1 is 30-31lb an marine is 42lb
Old 07-30-2012, 08:31 AM
  #23
Vortec350ss's Avatar
You'll want the marines... the 31's won't last you lone in a 6.0 with a mid 220's cam and 243 heads.
This thing should make good power!
Old 07-30-2012, 08:46 PM
  #24
another question can 243 heads make 400 whp stock, with a 224 cam, I'm pretty sure i'm doing work because I'm pulling the heads anyway but i was thinking of trying them with just a fresh valve job but i don't want to put this thing together and be disapointed, i thought the 317 heads flow as good as the 243 but with larger combustion chamber but now i'm not so sure what are you guys making with stock 243 heads
Old 07-30-2012, 10:17 PM
  #25
13 Second Truck Club
grey matter 04's Avatar
I think you come very very close to 400 hp with stock 243s.Depending on the dyno!
My buddy has a lq4 with 317s and a tr224 in a 4x4 he made 365 at FMS
A few LS1 with full bolt-ons and a tr224 have made 400 hp before
Also the 243s flow roughly 20 cfm more on intake and roughly 10 cfm more on exhaust.
Plus the bump in compression
Old 07-31-2012, 01:15 AM
  #26
didn't know they flow better but good point on the compression bump so that with the 4 bolt tb intake bigger tb, different cam and bigger maff will get me close but i think working on them might be a better choice more now less in the long run those gaskets are expensive better to do it once
Old 08-02-2012, 01:54 AM
  #27
mhotrodscooter's Avatar
I made 381 with a 221/226 cam with milled stock 243's.
Old 08-11-2012, 05:57 AM
  #28
I'm sending my heads to AI for thier 226 cnc porting and i'm getting there head and cam kit for 1800 head work a cam speced to them and head gaskets and pushrods along with the vavle springs, they claim ls2s make between 420 to 450 whp with the 226 cnc package, i won't be able to put them on till october i'll post results
Old 08-11-2012, 02:44 PM
  #29
With those heads you will make real good power. I've seen dyno's that show 50 HP from their port job over stock 243's with no other changes. You're gonna have a burner on your hands for sure!!!
Old 08-11-2012, 03:56 PM
  #30
oakley6575's Avatar
Yea that will be a fun truck. Shouldn't have a problem meeting your goals. All it takes are some good heads and it looks like you will have some.
Quick Reply: want to make 400 whp with 6.0
