want a mild to wild exhaust for my cammed 5.3?
my current setup is
5.3 with obx 1.75 to 2.5 i want to change the collector to 3 will that help the performance or sound reduction?
the y pipe is 2.5 into 3 wich is a 4 pice that always gets losen by time or road bumb or offroad trips
the mufller is the magnaflow round 30" case single 3 dual 2.5 and tail paipes are 3" with 4" tips
what i want now is somthing less noisy with no drone
i heard alot of good things about the xr-1 but still couldent decide
what i have in mind is
change the header collector to 3" and custom the y pipe as a 3.5 or 4"(for posible FI in the future)
then add a 3.5 or 4" borla xr-1 with a bullet in front of it to act like a resonator
is that a good setup?
how about a tru dual with aeroturbines (the diesel muffler)
all i want is a quite warm up with good exhaust note like the xr-1 and no highway drone and good sounding WOT
single exhaust is preferd
edit : the truck is cammed and it got louder than befor
I got tired of drone and got a SI/SO Dynomax VT, it does exactly what it says, really quiet at idle/part throttle/cruise and sounds good after that. It has a valve inside. It's quiet though, wish it was louder but I have an otherwise stock system...yours might have better results. ZERO drone is worth a little quieter note to me though.
how about these as a single 4" diesel muffler i bet this could handel the boost and be quite
dB Performance Exhaust by Corsa - Mufflers - Exhaust - SummitRacing.com
just installed a 2 thread shorter bolt from the cam plate , they are also arp and have the same size except the length as stated 2 threads shorter
and after i completed the swap and drove for 300+ miles i opend the hood and there it was , seting on the extra battery tray
damn was i mad
damn was i mad
