Want to order HPTuners, got some questions
Old 06-21-2005 | 12:17 AM
thunder550's Avatar
High on diesel fumes
Default Want to order HPTuners, got some questions
I am going to probably start by logging and letting pcmforless send me updates, then will eventually get into doing my own tuning with a wideband O2 and whatnot. I am planning on doing a 6.0 swap later this year and want to be able to do my own tuning by then. So...
Which package should I buy...which enhancements (1 bar/2 bar)?
I'm assuming my PCM will run the 6.0 with some tweaks, is this right?
Old 06-21-2005 | 06:18 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Your pcm will run the 6L but I dont have a clue when it comes to the actual tuning. Allen said he would jsut retune my pcm when I do the swap.
Old 06-21-2005 | 08:34 AM
12secSS's Avatar
How much boost are you planning on running? For N/A application that want to run MAFless, the 1 BAR is the enhancement that is required. For boosted applications you need the 2 BAR enhancement. For outrageous boost applications you can get the 3 BAR enhancement.
The 6.0L will run fine with slight modifications. Good luck!
Old 06-21-2005 | 08:50 AM
thunder550's Avatar
I think I'm also gonna pulley the Radix, from what I've heard the max I can possibly run is about 10-12 psi with the smallest pulley (2.75"), so that's about the limit. Is there and advantage to running MAFless? I was figuring that I'd keep the MAF, but I don't know much about it. Thanks!
5.3lSilverado
25
08-29-2016 12:48 AM
Lamartian92
09-10-2015 09:27 PM
Lamartian92
08-21-2015 01:43 PM
USMCvet0311
08-01-2015 07:45 AM
oharajo
07-18-2015 09:24 PM
Quick Reply: Want to order HPTuners, got some questions
