Weighed My Truck (SCSB)
Old 09-13-2004 | 01:13 PM
FILE's Avatar
Originally Posted by SportSide 5.3
Tiburon, you have to figure in traction to. If your hooking up perfect now, will taking off 100 lbs in the rear help? Just an example
I don't have traction as it is even with my 20's. I am sersoully getting some DR. However, if 100lb meant I was would be getting traction, I would keep those 100 pounds.
Old 09-13-2004 | 02:04 PM
Arigom's Avatar
What does a fully loaded Tahoe weigh?
Old 09-13-2004 | 02:07 PM
FILE's Avatar
my friend's Escalade with a 5.3 came in at 5,420 pounds.
Old 09-13-2004 | 02:15 PM
Arigom's Avatar
OUCH!! No wonder I can't get out of my own way right now.
Old 09-13-2004 | 02:36 PM
gonzo 6.2's Avatar
My buddys HO yukon Denali weighs 5800LBS,I put my quad in the back of my truck to get a closer to even match I weighed in at 6K on the nose,thanks to his AP engineering heads and cam also AZ speeds,yank and LS1 edit,custom catback,he pulled me,the way he pulled me it looked like he had another 25HP.All my buddys goal was after spendy $3500 in parts was to run with my truck,he's happy.
Old 09-13-2004 | 03:13 PM
abbo7's Avatar
Originally Posted by zippy
is this 2wd?
Yep, 2WD.
I thought Escalade's only came with the LQ9 6.0L? Did he drop in the 5.3L?
Old 09-13-2004 | 04:01 PM
FILE's Avatar
Originally Posted by abbo7
Yep, 2WD.
The base model comes in a 2wd 5.3 and the 6.0 awd is an option.
Old 09-13-2004 | 04:03 PM
zippy's Avatar
5.3 came in the 2wd escalade's.
sorry, i think i must have been typing it around the same time.
Old 09-13-2004 | 04:07 PM
Hardtop's Avatar
I'm going to have to weigh my truck. It should be pretty light. No power windows or cruise, 16" wheels.
Bruce
Old 09-13-2004 | 04:19 PM
Yelo's Avatar
5660lbs......1/2 tank of gas, 5th wheel hitch, frame hitch, and the 20's, just a bit porky isn't she.......heh heh
Quick Reply: Weighed My Truck (SCSB)
