Weird Idle surge
Old 03-14-2003 | 02:26 PM
The Big Show's Avatar
Default Weird Idle surge
Sup guys/gals..my friend has a 01 Tahoe and when the truck comes to a stop and is idling, the truck starts surging and acting like its going to die. My first thought was tps but I thought I'd post on here and get some ideas from people who actually own these vehicles. Thanks for any input!
Old 03-14-2003 | 03:49 PM
FarmTruc's Avatar
Performance Trucks Sponsor
Default Re: Weird Idle surge
what mods are done to it,
vacuum leaks?
Old 03-14-2003 | 04:45 PM
No mods, it's bone stock.
Old 03-14-2003 | 08:50 PM
LIGHTNINROD's Avatar
It could be a vacuum leak but, I believe it's the IAC(Idle Air Control) valve. They get carboned-up/sticky and let too much air in at idle rpms. I d/k about your specific one but all EFI vehicles have them and your problem is common. Usually, you can just remove it and soak /flush it with a solvent and it will be OK. If cleaning it doesn't help or last, replace it.
Dan
Old 03-14-2003 | 08:57 PM
BlueSS's Avatar
Do 01's have egr??? if they do, when I shaved the egr tube on my 00 the O gasket din't sit right and it idled like $hi+... Maybe sum how that gasket moved and isn't sittin right, once I was moving my truck would accelerate by it's self fixed the O gasket on the egr problem solved... Good luck
Old 03-14-2003 | 10:17 PM
My Tahoe did the samething cleaning the throttlebody cured the problem.
SloSVO
11-22-2020 08:34 PM
bearden86
26
11-15-2015 04:58 PM
BlownHD
10-03-2015 01:24 PM
02AWDAWSDenali
10-01-2015 06:08 PM
Chevy305
09-28-2015 10:21 PM
