Weird noise from eaton
as i read through this post i see something that bothers me my tires chirp at low speed sharp turns and i did not think anything of this until i read this and it makes me if this is a problem i am definately pissed off because i just let my truck roll out of warranty can someone help or PM me or something
Truck addict
my truck does that too but i think it is from raised line pressure and a vett servo. i don't think i have a problem with my rear end! i don't know if you have any tuning that raised the pressure or any tranny shift kits in or not
14 Second Truck Club
Use non synthetic lubricant and 2 bottles of additive. For clutch style posis I use the ford stuff m19546a. The gm stuff is real good for Auburns, which were stock in many of their cars for a while. Ford has always used Clutch style units, and I have always had good success with their additive. You can try one, but some additives say 1 bottle per quart of gear lube. After you lube it up, get it to operating temperature then drive in figure 8's, that allows both sides of the diff to work evenly and saturate the clutches in oil.
lukn4trbl355
10-21-2015 11:19 PM
