my buddy got stainless cats, can I just use my MIG to weld them into the ORY pacesetter sent? or does it have to have a certain gas. Im hopin not and its just more the heat settings.
To weld SS to steel, you should use SS filler rod or wire.
It is possible but not recommended to weld SS with regular mild steel wire.
You would also need a Tri-Mix gas for SS Mig welding.
soon, we got a lincoln welder for welding galvinized fence pipe. i believe i had used to weld stainless, its only two welds so Im not going to buy all that for just two welds, sounds like itll be fine if I weld em with what I got.
Thats cool.
Just wondering how soon, I have a Tig welder. But, my generator is on the fritz.
If I can get it running I could swing by and zap it for you.
