Well... replaced water pump but... no longer have a fan on the truck
Old 02-20-2010, 04:38 PM
Avalanche2002's Avatar
Mine came off with the same treatment only I used a rubber mallet on the Crescent wrench. It came loose after the second hit. Mine's in the rafters of my garage if you're interested in it. I have no clue what it's worth and I'm guessing shipping won't be dirt cheap since it's got a little weight behind it. It was on the truck for no more than 15k miles.
Old 02-20-2010, 05:29 PM
Parke10's Avatar
Originally Posted by KySilverado
It is reverse threads IIRC.
last few i have worked on have been,but i think i remember reading somewhere that only the older ones are like this.
Old 02-20-2010, 05:40 PM
Baltimore Whore
Mangled03gmc's Avatar
I used the cloths hanger method, to keep it from turning, a big wrench and hammer. It was a bitch but got it... You will def need the fan, or it will heat up on you... HEAT IS YOUR FRIEND, ALONG WITH A VISE NOW.
Old 02-20-2010, 06:21 PM
neilownz's Avatar
Or just find someone to sell you one cheap.
Old 02-20-2010, 06:33 PM
Baltimore Whore
I have a extra 1
Old 02-20-2010, 09:47 PM
Mrgoodwrench3's Avatar
1/2 a second with an air hammer will break it loose.
Old 02-20-2010, 09:53 PM
13 Second Truck Club
DV2000NJ's Avatar
I had the same issue, so I pulled the back cover off the pump, and welded a piece of flat steel long enough to keep it from spinning to the back of the impeller. Came off with no issues after that.
Old 02-20-2010, 10:51 PM
I used a strap wrench on the pulley and a big *** wrench on the nut and cranked like a ****. Of course, when it broke loose the wrench slipped and my fist landed in my nose.
Old 02-20-2010, 11:12 PM
006rcsb's Avatar
take a blue wrench to it then get on it with the big *** crescent.
Old 02-20-2010, 11:51 PM
Black'Rado's Avatar
i sprayed mine with some pb blaster and used a big cresent and jus smacked the hell out of it with a 5lb sledge a few times and it broke loose.
Quick Reply: Well... replaced water pump but... no longer have a fan on the truck
